96 kw w900l fuse/electrical help.,bunk lighter plugs
Discussion in 'Kenworth Forum' started by sparky88, Nov 15, 2014.
  1. sparky88
    sparky88 Light Load Member
    143
    31
    Jan 22, 2014
    oswego, ny
    Can anyone tell me Where the fuses would be or other suggestions. All 3 lighter plugs in the sleeper are dead. I see the fuse box and there are only 4 normal fuses in it along with a bunch of black relays. Not sure the actual location and i don't have a diagram
  3. 062
    062 Road Train Member
    6,143
    33,179
    Oct 20, 2013
    Not sure on a kw,on my fld it's behind the socket.
  4. sparky88
    143
    31
    Jan 22, 2014
    oswego, ny
    I didn't even think of that. I figured it would be in the fuse panel. Will have to check that in the morning
  5. Skate-Board
    Skate-Board Road Train Member
    3,801
    3,995
    Aug 9, 2014
    Merrimack, NH
    I have a Western Star and there is a metal box with a cover on it and fuses inside under the bunk
  6. sparky88
    143
    31
    Jan 22, 2014
    oswego, ny
    I'll go check it out in a bit. Thank you
  7. sparky88
    143
    31
    Jan 22, 2014
    oswego, ny
    Well there isn't fuses on the back of the plugs, no fuses boxes in the rear anywhere. So I'm guessing i will have to pull each of the big black fuses out of the fuse box and test each one
  8. sparky88
    143
    31
    Jan 22, 2014
    oswego, ny
    I'm stumped because all the fuses are good. I might say screw it and pull all 3 out, cap the wires and run wires directly from the batteries too new ones with a switch and fuses
  9. Skate-Board
    3,801
    3,995
    Aug 9, 2014
    Merrimack, NH
    There has to be another fuse box. I would start searching for the manual on your truck
  10. sparky88
    143
    31
    Jan 22, 2014
    oswego, ny
    The owners manual i have says the fuse panel is next to the steering column. I might have to get ahold of kenworth
  11. 062
    6,143
    33,179
    Oct 20, 2013
    Have you checked for ground?
