95 KW t800 with n14 power steering fluid change... how to?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by JakeBrakeChampion, Dec 15, 2012.
  1. JakeBrakeChampion
    JakeBrakeChampion Light Load Member
    55
    19
    Apr 14, 2011
    Pennsylvania
    How do i go about servicing the power steering system on my truck? Its a 95 with a trw steer box and has a steer assist on passenger side. What type of fluid is recommended? Atf ,15-40? Any filters? Thanx
  3. jbourque
    jbourque Heavy Load Member
    924
    553
    Oct 25, 2012
    south english iowa
    some of the older units run 20 weight oil. i would check with the dealer
  4. truckmechanic
    truckmechanic Medium Load Member
    534
    140
    Jan 14, 2012
    Hi Desert Ca
    There should be a filter in the resivoir the number should be stamped in the. Housing also you can slush it by pulling the return line from the box to resivoir I plug of the resivoir and outt the hose from the box in a 5 gallon bucket have someone get in the truck and start it while you keep the fluid roped off have them turn the wheels lock to lock untill you have clean fluid then change the filter top off the fluid and your good to go
  5. 1johnb
    1johnb Medium Load Member
    542
    405
    Jun 13, 2012
    New Paris Ohio
    If it is a sheaperd box 15/40 is fine, I usually put it in trw boxes also.
