My truck is almost ready to be put on the road. I wanted to put new universals in the drive shaft. It's a 95 Freightliner with 40,000 lb Rockwell Rears. Does anyone know the part number for them?
This is a truck that I have not run myself yet since I bought it, so I was wondering if I should have the drive shafts balanced while I have it out and apart. Is it a problem if I do not have them balanced?
95 Freightliner Driveshaft balancing and universals
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Dino soar, Jan 9, 2019.
The easiest way is to call your freightliner dealer with your vin. They can look it up.
However if they cant or somebody modified the driveline at some point, then It depends on what series of driveline you have. You can measure the u-joints from end cap to end cap and measure cap diameter to see what size they are, and then look up accordingly.
Heres some typical spicer drivelines just for and example of measurement
As far as balancing a driveline, unless you have a shake or vibration now, it's not all that important but it doesnt hurt to have it done either.
if you have a reputable driveline shop, its usually pretty inexpensive to have done. I balance mine when I do a clutch or transmission job on my truck just for peace of mind. It's not always necessary, but it's worth it to me. Just a personal preference honestly.Last edited: Jan 9, 2019
Rideandrepair, AModelCat and Heavyd Thank this. -
@Dino soar , if you do decide to take your driveshafts in for a balance, it's a good time to have them do a carrier bear too. Those are cheap and sometimes the midship yokes are stuck on, so it's best to have a shop press them off. Carrier bearing are in the 50 to 80 dollar range give or take for a typical spicer.
Rideandrepair and AModelCat Thank this. -
I redid mine a couple yrs ago. Had new yoke welded onto driveshaft.Did a new Carrier bearing and new intermediate yoke.I didn’t use torque wrench however and a week later noticed a broken bolt on rear driveshaft yoke. Tried to ez out and broke it off in driveshaft.Had to pull and have new one welded on at a different Shop. Neither Shop did balancing.Recently heard of a shop that balances both as a unit. The first Shop removed original weight.I was mad so found second Shop, they replaced yoke a little off from proper location. I plan on getting it balanced next time I do u joints.No noticeable vibrations it works but it’s not like factory. My advice based on my aggravating experience is mark position of yokes/ driveshafts before removal. If not possible if there’s a vibration usually remove and install slip yoke 180 degrees. Use new bolts, pack yoke with grease, and use Lock tight and a torque wrench!! Made me a believer
Dino soar Thanks this. -
The less you mess with it the better I say?
Had mine done once, then again, then again....
Treat it like a sore dick and quit screwing with it!snowman_w900 Thanks this. -
And I always use the same guys that I know do a good job. Nothing is ever guaranteed but atleast if it dont turn out perfectly, they will make it right. Getting hard to find good shops to do anything correctly and stand behind it these days.Tug Toy Thanks this. -
I agree,The Shop I used in the past had closed down. The first shop I used this time does driveline only. Very busy Shop recommended by others. Second time I used one of the busiest Truck Repair Shops in Town, with an in house driveshaft repair, again highly reputable Both in Detroit area. Recently at a Freightliner in Ohio, I was admiring a set of rebuilt driveshafts. I asked who did the work. They explained they ship them to Detroit and are balanced as a set, So next time they’ll get my bussiness. I ran my truck for a long time with a bad yoke.Went through 2 rear u joints in 6 yrs.The Truck had 1.7 mil on it at time.I like to fix it right, myself. The two things I farmed out got screwed up IMO. Shops however disagree. If I didn’t know what I had and hadn’t done same on my last Truck ( rebuilt driveline). I’d have no idea. It’s still working good after 400 k.Total cost for everything parts and shop work about $800. But next time it will be perfect.Too many shops figure what you don’t know won’t hurt you.
Well I'm debating whether or not I should have it done since I have them out.
There's a place in my area that is a transmission shop and they do Driveline work and I've been to the shop before. I watched how they Made a new drive shaft and I watch they had a machine almost like a lathe that they balance the drive shaft. On that same lathe type machine they had a welder setup that everything was timed so that the driveshaft would roll as the weld would go on. I don't think they are cheap, because I think it probably would cost me $300 to $500 for them to to balance them, but I do think they would do the job right. They have one guy that's been working there for I don't know how many years doing that. I would trust them to do the carrier bearing and whatever else.
I just don't know if I should have it done at this time. I have money to work with but getting started is still tough. 500 here 500 there 500 for something else it all really adds up.
Then again I have new pinion seals new transmission seal new universals, maybe I should just go ahead and finish it and be done with it. Still got a little time to think about it...Rideandrepair Thanks this. -
Carrier bearing was a piece of cake on mine.Very simple and cheap to do yourself. Just make sure all the yokes aren’t egg holed and re install all in line with each other
