'94 Mack E7 427 Oil leaks
Discussion in 'Trucks [ Eighteen Wheelers ]' started by CaboverKid, Mar 29, 2015.
  1. CaboverKid
    CaboverKid Light Load Member
    138
    31
    Dec 20, 2014
    Hey guys, I have a CL613 n its got a leak. The best way to describe it is its a square shape box mounted to the front of the injector pump. There is some kinda solenoid bolted to the side of it with a guard plate over top of it. The leak is between the square box thing and the cast piece that its bolted to. What is this thing called? My local Mack dealer is of no help for trying to help me order the right gasket.
    Also, is there anyway to get more TQ outa these engines without buying one of those generic power bixes? Ive called Pittsburg Power and a couple local ECM tuner guts n nobody seems to have any kinda upgrade for a Mack engine, even a proper one. I drive at 58 mph n pull a reefer n cant get more then 6 mpg...these were supposed to be fuel efficient engines...
  3. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    may be it is injection advance unit?
    ore heat exchanger
    can u post a picture?
  4. CaboverKid
    138
    31
    Dec 20, 2014
    I will get a pic when I stop in a couple hrs.
  5. Ok big boy
    Ok big boy Light Load Member
    77
    78
    Jan 22, 2014
  6. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    Sometimes I use to work on old Mack engines.
    E6 was very durable engine!
  7. Mack427
    Mack427 Medium Load Member
    323
    93
    Jan 22, 2009
    blixxton box is a good on those older e7's 30% more power (there fairly cheap now) ill. dyno center can get a hotter file for you too. if your not wanting to go that route high flow injectors and upgrade turbo is about it.
  8. CaboverKid
    138
    31
    Dec 20, 2014
    I wonder though if the generic power box is gonna change the fuel map enough to get me better fuel mileage, or just more power? It seems to be running rich now, clean air filter n no air to air leaks...but she can really roll coal when ya get on er. I wanna change that but not sure if the fuel pump is adjustable...
