I know its not a semi but funds from this sale are to repair my down semi..... please help thanks big car for big guys lol.
selling my mostly stock buick gs roadmaster 1994 great car and ready to drive anywhere. Need to sell..... with only 62k miles and custom daily driver can be driven anywhere need be for the price of a regular ugly daily driven caR.
Engine: Low mileage 62K miles StocK LT1 350 5.7L MPFI has had new msd distributor,msd wires 9mm and ngk plugs installed,Msd blaster 2 coil,AIR/Emissions delete all plugs there uncut,3,5" custom aluminum intake air kit with brand new spectre cone air filter and outerwears screen,descreened MAF,IAC relocation harness,Has newer power steering and starter replaced within 2 months time,New GM OEM radiator assembly as well as upgraded Impala ss Electric Fans HD motors FAn motor Relay kit,Hypertech 160 t-stat,New upper and lower radiator hoses,recent oil change with k&n hp2001 fitler always meticulously maintained and serviced, no blow by on engine,New Fuel Rail Mounted fuel pressure guage,Lt4 knock module,PCM Forless computer tune.ICE COLD AC AND HEATER BOTH WORK FINE.Cats have been deleted custom at muffler shop as well as two brand new SLP performance mufflers installed tailpipe are right over the differential as resonators have been deleted,Brand new Bosch Intank fuel pump and gm fuel level sender as well as ac delco fuel filter.2 New DElphi 02 sensors installed as well.
Transmission: Stock fluid flushed and serviced 5k miles ago new filter and fluid added as well as rear seal,new poly urethane trans mount energy suspension.
Differential: Stock open non-posi 2.56 gears great on fuel gets 24-26mpg hwy which is a lot for this size car, new outer axles seals,and fluids as well as correct cover gasket installed.
Wheels & Tires: 2013 Stock brand new almost just 5k miles on them hardly ridden 2013 Camaro rs black steel 18" wheels with no hit bends or scrapes,with trim rings and custom buick wheel center caps, tires are the stock 245/55/18 bfg Goodrich 620 tread wear tires with 95% tread still left on all 4 tires.
Steering & Suspension: Steering has brand new moog outer and inner tie rod ends and adjusting sleeves,problem solver idler arm,both upper control arm ball joints have been replaced with moogs,energy suspension sway bar end link kit,energy susp bump stops,H&R drop lowering springs front and rear,Stock Monroe shocks in front and rear,new oem gm front coil spring isolaters,energy suspension rear coil isolaters,Steering is not loose doesn't pull to any side and tires have even wear, car doesn't lean to any side either sits evenly on ground,the steering gear box isn't all loose with play its nice and tight.Impala ss Frnt and rear swaybars.
Exterior: Car is originally Burgudy in color on the outside its is now been plastidipped about 1month ago and is nice in color and not peeling at any location the original paint on car is good but is faded on roof and hood, all chrome mouldings from side of body have been deleted (I no longer have them) . Buick GS Grand Sport Badges added as well. Car has HID 6k ultra white headlamps all turn signal and lamps all work on the exterior of the car. Car has a couple dents and dings but nothing large, as well as no rust just some surface rust on the chassis.
Interior: Burgundy leather top of dash has one crack other then that its complete,all gauges on dash work without any problems,all interior lamps work as well,window rollers have been all fixed,they all go up and down no issues,driver power seat works all postions,power locks,cruise control and power mirrors all work,Driver side seat has a 3" tear on the upper back part of the car,pass front seat has small ciggerate lighter hole,rear seat is in good condition and all door panels nice and tight on doors and not hanging.Has a 2012 pioneer premier radio with usb,1500x2 audiopipe amp for bass and 2-10" pioneer speakers in individual boxes.Has normal heel wear spot on driver side front part of carpet, headliner is nice and not sagging, car has 25% performance tints.
car starts on the dot everytime and can be driven anywhere as long as there is fuel and driver would drive anywhere as it has great tires.
$3250 obo
car is currently on ebay click on link below to view: http://cgi.ebay.com/ebaymotors/1994...649&ssPageName=STRK:MESELX:IT&forcev4exp=true
94' Buick Roadmaster RMS/GS custom*62k miles* Daily Driver
Discussion in 'Trucker Forum Classifieds & Trading Post' started by flc120, Sep 3, 2013.
- Thread Status:
- Not open for further replies.
Those cars ride so smooth and have tons of power.
If I hadn't just bought a truck I'd take a bus to FL and grab this. Sharp!!!
flc120 Thanks this. -
thanks guys she really I a nice DD runs like a top.
$2500 stock radio installed but not working I pulled out sound system. And reinstalled stock headlamps one of the HID bulbs blew out.
sold locally thanks
I got a 96 Caprice that runs like a top and flies like the wind. Love that car. Sorry you had to lose yours man. There's another one around the corner though.
- Thread Status:
