Is this route open? Google maps showing it closed or maybe one side closed between Henderson and Boulder City. Not much info NV DOT website...
93 from Kingman to Vegas
Discussion in 'Experienced Truckers' Advice' started by thaistick, Nov 18, 2017.
Page 1 of 5
Last time I tried that way you need to head over to 95 because they do not let trucks over that dam
They are working on the Boulder bypass so there is construction but everything was open this past week.rabbiporkchop, thaistick and bigkev1115 Thank this. -
That s the new bypass around the Hoover Dam. The Mike O'Callaghan-Pat Tillman Memorial Bridgetscottme, a-trucker123 and Dave_in_AZ Thank this. -
Aw man, then you do not get to see the rock that is flipping humanity off, and driving across that dam decades ago was a experience, but it will cut a bunch of miles off.
It's open though. Soon that will be Interstate 19 from Las Vegas to Phoenix.thaistick and AfterShock Thank this. -
Actually, its going to be Interstate 11 between Las Vegas and Phoenix
bzinger Thanks this. -
fargonaz and bigkev1115 Thank this.
YOU WILL NOT be allowed over that dam.
There is a very high bridge that 4 people died building for trucks to cross and to maintain a route connection in case that big dam should ever fail. That will be the bridge you will be using to get to vegas.
Once past there, vegas is not a problem at night you will be seeing the lights as soon you clear the dam. -
The wort part of going to Vegas was having to dodge tourists on the dam, yet I'm still a little sad that it's no longer an option.
kemosabi49 and x1Heavy Thank this.
Page 1 of 5
