9 speed eaton vs 10 speed
Discussion in 'Ask An Owner Operator' started by JohnsonWayTrucking, Dec 26, 2020.
  1. JohnsonWayTrucking
    JohnsonWayTrucking Bobtail Member
    41
    22
    Oct 10, 2020
    Hey guys looking at a 15 freightliner with a DD15 455hp and 3.25 rear low mileage for a great price my only issue is it's an 9 speed and 254 inch wheel base. This truck was made for flatbed I need it for dry van and reef. Has anyone driven 9 speed OTR.
    How are they.
    singlescrewshaker Thanks this.
  3. DUNE-T
    DUNE-T Road Train Member
    6,876
    16,597
    May 10, 2015
    Detroit, MI
    I wonder if that 9 speed is easily convertible to a 13 speed
    singlescrewshaker and magoo68 Thank this.
  4. JohnsonWayTrucking
    41
    22
    Oct 10, 2020
    Yes I can convert it for pretty cheap but that doesnt change your final drive. Just give you more choices in btwn gears.
  5. Judge
    84,414
    9 speeds aren’t bad, little differences between gears, maybe 400 rpm vs 300 or so, TMC used 9 speeds for years OTR.
    It’s all in what you get used too.
  6. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,056
    Nov 18, 2014
    Land of local
    It's .73od with the 3.25 rears
  7. JohnsonWayTrucking
    41
    22
    Oct 10, 2020
    Would I get good mileage with .73od
  8. abyliks
    abyliks Road Train Member
    3,746
    8,694
    May 2, 2010
    ludlow MA
    If it’s a convertible 9 speed it should be something like a .83 in 9, the od box (to make it a 13, is what gives the .73, I believe a straight 9 is .74 in the big hole
    haycarter and singlescrewshaker Thank this.
  9. singlescrewshaker
    4,689
    40,504
    Dec 31, 2017
    Little Havana, FL
    Ratio
    Get the trans model number, check it against this Eaton Fuller link & you will know the ratios..
    If it an RTOC, definitely get it. Then spend the few hundred bucks & convert it to a 13..
    My 9 speed is .73 od. Most 10's in late models are FR direct drives, or FRO .74 od.. Top gear rpm should be slightly lower with the 9..
    A 9sp is the easiest transmission on the planet to drive, & tough as nails. You will never even need the low hole pulling a box, & it's just an easy H pattern repeated low/high.. I'll take a 9 over a 10 every time..
  10. singlescrewshaker
    4,689
    40,504
    Dec 31, 2017
    Little Havana, FL
    Most the convertibles it's an under drive box that the air lines aren't hooked up. Should still have the .73od as a 9 or 13.. As a 13, 12th under drive split will be .86..
    Roberts450 and Hammer166 Thank this.
  11. HillbillyDeluxeTruck
    5,878
    29,946
    Mar 3, 2013
    San Antone
    Rtloc-16909 is the convertible 9spd. Im currently having the conversion kit installed. You can call a Freightliner dealer with the vin and they can tell you what trans is in that truck.
