855 Cummins
Discussion in 'Trucks [ Eighteen Wheelers ]' started by A4T1600, Sep 19, 2015.
  1. A4T1600
    A4T1600 Bobtail Member
    15
    Feb 15, 2014
    Considering putting an 855 Cummins into an ag tractor. An articulated that currently has an OEM 300 hp that is blown. Anyone able to guide me on the merits of the big cam vs small cam 855. A friend did a conversion with a small cam, just wondering which engine would be best suited. It's obvious by my post I'm engine knowledge challenged-just trying to get a bit of an education. Appreciate any advice.
  3. FinkPloyd
    FinkPloyd Light Load Member
    206
    268
    Sep 2, 2015
    What kind Of Tractor? .....Steiger?
    What are The Specs on the Original motor?
    The older Panthers Came With Big cam Cummins Engines, And I think Some Years Of John deere Came With the n14 (the 855s spiritual successor) It absolutely can be done, But A Big Engine will only be as Powerful as the Transmission and Hydro pump behind it!
  4. 201
    201 Road Train Member
    12,044
    24,581
    Apr 16, 2014
    high plains colorado
    Hi a4t1600, the 855, I feel, was the best motor out there. Years ago, it was all 855's, with a few Cat's mixed in. I've trucked for many years, and nearly every truck I drove had a 855. ( even my own) The small cam, I feel had a little more power. Big cam means, I believe, the cam journals were bigger, which meant they could run lower oil pressure, theoretically, meaning less power to run the oil pump at 40 lbs. instead of 60 lbs, in a small cam, and better fuel economy, which it did. ( small cams got 5 mpg, while the Big Cam, got almost 6, or more, which probably won't make much difference in the field, and parts are everywhere. I worked at a farm that he bought a new JD chopper ( 10 years ago) and had an 855, and it did a good job. I'd go for it.
    slomofo Thanks this.
  5. mountaingote
    mountaingote Road Train Member
    2,026
    7,916
    Sep 22, 2012
    Most of the 855s I ever drove got some here between 3 and 4 mpg. I saw lots of them that never made it to 200k before they had to be overhauled.
  6. 201
    12,044
    24,581
    Apr 16, 2014
    Hi mountaingote, I beg to differ. Cummins 855's routinely go between 350 and 400k without a rebuild. And the rebuilds, generally, are much cheaper than say a newer Detroit or a Cat. Most people that don't get that kind of mileage, usually drive them too hard, you have to "baby" a Cummins, as they aren't the most powerful motors, but a Cummins motor never left me stranded. I got between 6 and 6.5 all day long (Big Cam). Sorry, I'm a firm believer in a 855 Cummins.
    rocknroll81 and OLDSKOOLERnWV Thank this.
  7. IH Truck Guy
    4,118
    46,687
    Mar 2, 2008
    Purgatory
    855 Cummins is like a 350 Chevy motor.
    Just about anybody can rebuild one.
    I rolled in a set of bearings at 240,000..
    Truck was still running great,when I sold it with 495,000 miles.
    rocknroll81 and 201 Thank this.
  8. old iron
    old iron Road Train Member
    1,126
    19,701
    Feb 19, 2011
    Northern Wi
    I have an old 800 versatile articulated. It has a small cam 855 no turbo set at 250 hp. It has all the torque it needs. No need for a power shift just throttle it back, round the corner and push it ahead and away you go.
    BoxCarKidd Thanks this.
  9. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,431
    Aug 26, 2014
    Merits of big cam over small cam: Longer head bolts less prone to brake. Camshaft is larger in diameter and should last longer. All had piston cooling nozzles. Newer and easier to get parts. All had poly groove water pump belts. All had turbo's and are more efficient than small cams without. That is my answer to your question so someone can tell me I am wrong.
    I do not hate small cams and a friend of mine has army 6x6's with 240 small cams, made in 1990, pulling dumps under a corn chopper. They do a good job for him as one of those engines would for you. It is not all about HP, the long stroke produces torque and lugging power. There is also no substitute for cubic inches.
    If gote's 200K overhauls were due to liners allowing coolant to leak under the head I also saw that at one time.
    I agree with Mr. retired. The mileage on turbo engines was normally 5- 7.5 mpg and we expected to see 600K before the heads came off.
    1600 : If you buy a big cam be sure it does not have low flow cooling for what you are doing. Would it not make you the coolest guy around if you bought a naturally asperated 12V Detroit with split manifolds and two three inch chrome straight pipes with flappers on each side?
    rank and 201 Thank this.
  10. KenworthGuyNH
    KenworthGuyNH Road Train Member
    1,050
    2,686
    Dec 11, 2011
    Central, NH
    Care to elaborate?? Application?? 6.31 rears and an auto in the toy soldiers?? This runs counter to my experience with older Cummins...........
  11. BoxCarKidd
    4,418
    6,431
    Aug 26, 2014
    Rears? Trans: Big 5 speed auto. It runs counter to my experience also. I may have confused the year with the one with an 8.3. Could be mid 80's. Still years after I thought production had stopped except for the Komatsu-Cummins small cam. Should not have brought it up and just said some later model military salvage trucks have N855s, small cams, with almost no miles. I have seen good results from them. Non-turbo, turbo, turbo and after cooled equals good, better, best. On the farm that works out something like 80, 70, or 60 gallons per day.
    KenworthGuyNH Thanks this.
