84 KW, 350 Big Cam Cummins, Red coolant?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by herbiemin, Sep 21, 2016.
  1. herbiemin
    herbiemin Light Load Member
    94
    50
    Dec 20, 2014
    Was working on the truck the other day and decided to flush the cooling system as it hasnt been done since we bought the truck. After washing and rinsing for about an hour and a half and still getting rusty, goopy looking brown water out of the bottom of the radiator. Obviously the previous owner didnt believe in doing anything except adding water. Anyway after i run some cleaner through it, is there any reason i cant refill with the extended life red coolant? Will it cause water pump problems or anything? Just want to make sure it wont cause problems in an older engine. I dont mind running green and testing it every now and then, but the low maintenance of the other sure is nice. Any preferred brands of antifreeze? Thanks
  3. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,129
    Mar 5, 2016
    White County, Arkansas
    That is a old CAT Extended life coolant.
    Flush it, pull hoses back flush everything. And do not mix with any other red coolant should it still be available. There is nothing that says you cannot use ordinary 50/50 green or other as long it's water based.
    Double check and see if CAT still makes the Red coolant for that engine.
    It's been a life time since I dealt with the big cams and am more towards replacing sensors and stuff on those things back in the day leaving the cooling fluid to someone else. If I remember right, it was always the green and water mix. Slop it into the rad in the morning before rolling. The smell is instant recognizing when there was a blown heater core as happened a few times that leaked like crazy.
  4. BigPerm
    BigPerm Medium Load Member
    I wouldn't pay CAT prices for Extended-Life coolant, but at the same time, don't go to an auto parts store either. Use a good H.D. coolant from your truck supplier. Coolants can be mixed, but if you go with E.L. coolant, don't mix reg/green because it will downgrade the E.L properties. Put some DCA in too with your new coolant filter.
  5. little cat 500
    2,044
    1,090
    Jan 17, 2010
    Abbottstown PA
    ive run the walmart green for years with no problems
  6. BigPerm
    Yep, you can, but the HD stuff has better corrosion properties and other stuff I can't remember right this second.
  7. AModelCat
    154,242
    Red and green don't play well together. Some people say they don't mix and others say it becomes sludge. Either way its not good.
  8. x1Heavy
    34,017
    42,129
    Mar 5, 2016
    Im inclined to follow the majority here in favor of no green into the Red ELC.
    Ive had very limited experience with coolant because for the most part I fixed bad gauges, sensors or blown heater cores where necessary, heavier repairs went to the shop. Ranging from a bad radiator cap to a water pump. The water pump failure was detected in philly by smell on 95, I did not stop thinking about it until Kenly Carolina and shut her off for bunk. Next morning she had dumped it all into a lake. It was a green lake and a small 350 cat.
    Thinking about coolant colors and so forth I simply do not have enough to work with. I thought the Red Coolant had gone away over the decades to history.
  9. SmokinCAT
    SmokinCAT Road Train Member
    1,773
    1,487
    Oct 20, 2010
    Hillsboro, OH./ Adrian, MI
    An older Cummins is designed to run green with a DCA additive and that it all.
    Diesel Dave Thanks this.
  10. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,431
    Aug 26, 2014
    I decided to change everything to extended life coolant some years ago. Only when a major refile was required with the goal of only having one anti-freeze that is supposed to be superior. Lost a few water pumps and stopped unless water pump is changed. Old Blue to the left is still green with the original radiator.
    x1Heavy Thanks this.
  11. herbiemin
    94
    50
    Dec 20, 2014
    Well I called Cummins today and they said if im doing a total flush and clean it should be fine to go back with the red. Kenworth had the TRP red on sale for $11 somthing a gallon premixed so grabbed several cases. Guess we will find out...
