730 Volvo fuel tanks not leveling
Discussion in 'Volvo Forum' started by Volvo 730, Jan 21, 2012.
  1. Volvo 730
    Volvo 730 Bobtail Member
    Jan 21, 2012
    Manitoba
    I got a 730 Volvo with a 500 cummins and the fuel tanks are not level it's pushing all the fuel in to the driver side tank and over flowing any body have any ideas what the problem could be
  3. mgfg
    mgfg Road Train Member
    1,753
    626
    Mar 29, 2010
    Check you vent on the pass side tank, even try running with the fuel cap loose to solve your problem. Are there taps to isolate a fuel tank?
    I see you are from MB, do you have a frozen return line by chance?
  4. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    it is the Volvo problem, dealers change pass side tank valves, but usually drivers add hand controled valves like on some Freightlener trucks and they oprtaye well
  5. pup
    pup Light Load Member
    252
    256
    Dec 3, 2011
    n.h.
    suction line on the drivers side could be blocked. Had a fuel tank rotate in the saddles enough to crimp the line. The driver knew it had moved but didn't think it would bother anything.
  6. Volvo 730
    Jan 21, 2012
    Manitoba
    Ok thanks I got it to work now
    gamage rivers Thanks this.
  7. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    we had the same issues not with VN only, but with Volvo cabovers (FH, FM), so, it is the global problem
  8. volvo_lover
    volvo_lover Bobtail Member
    charlottesville,va
    I got a 780 volvo engine and the fuel tanks are not level it's pushing all the fuel in to the driver side tank and over flowing any body have any ideas what the problem could be
  9. bossboy2
    bossboy2 Light Load Member
    264
    59
    Aug 20, 2011
    Houston, TX
    What was the problem?
