7 pin(semi) plug to 7 blade utility trailer
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Lazer, Oct 29, 2021.
  1. Lazer
    Lazer Road Train Member
    1,728
    2,721
    Jan 22, 2017
    Needing to pull a utility(car hauler) style trailer behind a class 8 straight truck with pintal hitch, that is wired for a pup trailer(semi trailer plug). This utility trailer has electric brakes, so won’t be needed that wire. Do the wire colors match up? The pulling truck does not have a electric brake controller, just air brakes. TIA
  3. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    No the pins do not match up.
    You would need to install an electric brake controller and wire in a seporate receptacle for the RV style plug. The other option, if you are never going to pull the trailer with any other vehicle is to change the trailer cord end to a round 7 pin and wire your electric brakes to the center pin. This will pose a problem if your heavy trailer is ABS equipped and you plan to switch back and forth regularly. Even though you may feel your big truck has more than enough braking power to stop the lighter trailer, electric trailer brakes will still need to function when and if DOT goes to check them.
    A5¢, BoxCarKidd, Oxbow and 2 others Thank this.
  4. Lazer
    1,728
    2,721
    Jan 22, 2017
    The electric brakes on the lighter trailer is the fly in the ointment here. We are limited to weight, due to the trailer is tandem axle but not duals. The tire size limits the total weight of trailer and cargo.
  5. Goodysnap
    3,694
    8,948
    Jul 12, 2017
    Weight carrying capacity of the axle/tires has nothing to do with the trailer brakes being connected to the towing vehicle and functioning.
    What am I missing?
    clausland Thanks this.
  6. clausland
    clausland Road Train Member
    1,933
    11,067
    Dec 5, 2014
    North Woods
    Nothing, I'm just guessing here, but I don't think he wants to buy, install, & wire an EBC to the truck; however, you're spot on, it is an OOS when inspected roadside, even worse if you have an accident, then the fun begins, roll the dice I guess...
    BoxCarKidd and Goodysnap Thank this.
  7. loudtom
    loudtom Road Train Member
    1,717
    2,800
    Aug 26, 2016
    You might also need a tail light converter for your truck. Most of the bumper pull and smaller trailers are combined systems, while class 8 trucks are separate systems. If you just match up the wires to the plug, your brake lights may not work.
  8. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,431
    Aug 26, 2014
    Just wire the tail - turn - stop lamps to the tail and turn signal wires on the semi. They will work fine. Disreguard the brake light wire used for a semi.
    If he swaps back and forth with trailer sizes just install two plugs on the truck.
  9. ZVar
    ZVar Road Train Member
    10,911
    23,825
    Sep 10, 2010
    Flint, MI
    Is this a one time thing or permanent?
    If it's permanent then there is an over the counter solution for the brakes. Will still have to wire up a pigtail though.
    https://www.etrailer.com/Trailer-Brake-Controller/Hayes/HA100400C.html
  10. jason6541
    jason6541 Road Train Member
    2,425
    5,365
    Mar 5, 2012
    Omaha, NE
    if you have no electric brakes hooked up on trailer, the truck will try to stop faster than trailer and possibly cause a Jack knife. Especially if on bad road surfaces or heavy rain and ice. Trailer starts swaying etc
  11. MacLean
    MacLean Road Train Member
    1,266
    3,712
    Sep 12, 2017
    Check out e-trailer. I believe they have a converter to go from 7 pin to 7 blade. But like stated above, having no brakes regardless of how light it is behind you is a major problem.
