I'm probably covering old ground, but I did a search and found nothing.
I see a lot of talk about different turbos for the 6NZ, PDI, Bully Dog, Michigan turbo, etc. I also understand Borg Warner has a non waste gated turbo for this engine. I've got the Bully Dog manifold on my engine now with the stock Cat turbo. Any recommendations would be appreciated. Like everyone else I'm looking for performance and mileage.
6NZ Turbocharger
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Nevs, Jan 23, 2011.
Page 1 of 9
Michigan Turbo's Stage 1 turbo is a BorgWarner 198123 this is an old design. It's very sluggish to respond compared to the other performance turbos sold by others and myself, but it's much cheaper in price also. You won't like it.
The comment about the exhaust turbine housings cracking was actually a BorgWarner production problem that was fixed a year or more ago. They were machining to much of the raw casting in one area making it too thin.........this made it crack. Some of the sellers listed above changed to a different part number turbine housing until the manufacturing problem at BorgWarner was fixed. Now you can use either exhaust turbine housing, depending on availablity and pricing.
The components to build these turbos can be hard to get at times depending on BW's production schedule and consumer demand at the moment. If you're interested in a turbo, PM met800kwopper and greenstar Thank this. -
pdi Uses a Borg-Warner Turbo.
Bully Dog along with Full Tilt Performance manufactor and build their own turbo, not a BW part in it. -
mr haney, how can you tell if your waste gate is working our not.
Buckshot7cz and t800kwopper Thank this.
So you've actually had a bully dog turbo first hand to compare it to? Or maybe you know someone that works for bully dog? -
t800kwopper Thanks this.
I love it.................sales hype
Rick Plauman is the best at selling sales hype
There are a few others I'd list as having the same abilities as that gentleman. As a salesman you create the illusion of having what everybody needs to have. The salesman creates the illusion that you can only satisfy that need with his exclusive part...........keep believing that and you'll make him rich.........tell all your friends how satisfied you are after the purchase of such an exclusive part and you'll make him richer
Why do you think everybody removes the part numbers?
IT'S a SECRET!!!!!!!!!!!!!!!starmac, 281ric, Buckshot7cz and 2 others Thank this.
Page 1 of 9
