60 series max reliable hp?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Turbrospeed, Jul 1, 2021.
  1. Turbrospeed
    Turbrospeed Light Load Member
    143
    111
    Apr 23, 2020
    Texas
    I got my 97 ddec 4 60 series rebuild last year with a oem inframe rebuild kit and oem injectors...currently have pai ceramic coated manifold, bw 75mm turbo, kn intake filter, 5inch straight pipe.... the mechanic who rebuild the motor said its turned up to 475 / 500 and that it wont last long if turned up to 550?
  3. feldsforever
    feldsforever Road Train Member
    1,453
    1,440
    Nov 22, 2019
  4. jamespmack
    213,256
    Well there is alot more to it. What series is it. Does it have piston oil squirters? Did he install updated drilled rods? Press on wrist pins, or bolt on?
    Any reputable tuner can guide you in the right direction.
  5. benjamin260_6
    benjamin260_6 Medium Load Member
    430
    480
    Aug 8, 2012
    Ontario, Canada
    A GK60 can run a long, happy life at 550hp if tuned correctly and driven responsibly. Around 600hp is about the max I like to go with them because of the lack of piston cooling nozzles but that's with and injector upgrade.
  6. Elroythekid
    Elroythekid Road Train Member
    2,604
    5,655
    Sep 9, 2010
    Halifax Nova Scotia
    What do you do that you need all the HP? My s60 is 435/475 I think, and I haul 43000 thru PA down to SC, lots of hills, then north up the middle to Ontario and dont have a problem. I'm told that tune so understresses them my engine should go 1.5mil no sweat?
    Rideandrepair Thanks this.
  7. benjamin260_6
    430
    480
    Aug 8, 2012
    Ontario, Canada
    275hp will still get the job done so why not turn yours down to that? You can get a good night's sleep in a 30" flat top so maybe that's what all trucks should have. No more 13 and 18 speed transmissions - 8s for everyone. It's been pretty hot this summer but no need for AC when we have crank windows to cool us off
    What I'm getting at is sometimes it's nice to have more than just the bare minimum
  8. MM71
    MM71 Heavy Load Member
    758
    987
    Jun 28, 2008
    AZ
    You keeping up with the maintenance of that K&N filter? I know 2 people that have dusted motors for lack of keeping those expensive pos filters sufficiently wet with oil.
    Last Call and Rideandrepair Thank this.
  9. Turbrospeed
    143
    111
    Apr 23, 2020
    Texas
    The one i have doesnt need oil....I always clean it with degreaser every 20k miles or so.
    jamespmack and Rideandrepair Thank this.
  10. Turbrospeed
    143
    111
    Apr 23, 2020
    Texas
    I would like to put my truck on a dyno to see exactly where she is at. Even though the mechanic said that i have such power, that could be false since i didnt really see them doing it. I have a scan gauge and boost only goes up to 31.5 psi, it also tells you the hp of the motor, before the inframe i saw up to 480hp on cruise up a steep hill.
    Now I have only seen just a bit over 300hp, Scan gauge has the same settings as before. Truck tends to lose momentum when rpms dip under 1300 on a steep grade going 70mph plus with a 10k or less load.... dry van all steel wheels with 295/75/22.5 tires.
    I use to run continental hdl super singles and a 10 speed...i change to a 13 speed because i had no overdrive on that 10. Was doing 65mph at 1600rpm on 11r front tires.
    In the rear I have steel inner and aluminum outer wheels on some crap thailand trazano 295/75/22.5 tires (bad invesment) which am itching to change out for some all positions for a smoother ride.
    Right now i have 2.9 rear end, doing 70mph at 1280 rpms due to the 13spd, might be thinking of putting maybe a 3.5 so i can cruise at 65mph around 1400
  11. jamespmack
    213,256
    Some late model years GK blocks are drilled for oil squirters all you have to do is add them. I even had a GK with them. But idk if they were factory or added. Then we built a BK with drilled rods.
