60 Series exhaust manifold leaking again?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Elroythekid, Feb 3, 2019.
  1. Elroythekid
    Elroythekid Road Train Member
    2,605
    5,657
    Sep 9, 2010
    Halifax Nova Scotia
    Have a 2012 Columbia glider with a 12.7 pre-emission 60 series. When I got the truck the manifold was leaking so I had all new gaskets including the slip joint gaskets replaced. They lasted 6 months so I had it pulled and did a new manifold and gaskets, including the slip joint gasket kit and... 1 year later, rear slip joint leaking again. Anyone have any ideas? Is there a one piece manifold available?
  3. rollin coal
    rollin coal Road Train Member
    13,087
    25,912
    Mar 29, 2008
    TN
    Stock 12.7 Detroit manifolds are junk. PDI, Full Tilt - several companies make manifolds for your motor that flow better, lower egts and more importantly never leak. They have the ISX type slip joints that don't leak. I've had a PDI manifold on my CAT for about 5 years or 6 years now and no leaking.
    Elroythekid Thanks this.
  4. Rudedud&Red
    Rudedud&Red Bobtail Member
    21
    9
    Feb 2, 2019
    Check your motor mounts
  5. Elroythekid
    2,605
    5,657
    Sep 9, 2010
    Halifax Nova Scotia
    Motor mounts?
  6. ibcalm19
    ibcalm19 Road Train Member
    1,463
    2,435
    Nov 30, 2015
    Pennsylvania
    Check out Bully Dog manifold they make the one piece you are looking for.
  7. Rudedud&Red
    21
    9
    Feb 2, 2019
  8. Brandt
    Brandt Road Train Member
    4,417
    5,954
    Sep 17, 2012
  9. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    First off , how does a motor mount correspond with a leaky exhaust manifold.???
    IH Truck Guy Thanks this.
  10. Elroythekid
    2,605
    5,657
    Sep 9, 2010
    Halifax Nova Scotia
    I get that... but wouldn't the flex pipe take all the beating if they were bad? I did have the mounts checked a while ago and was told they were OK. I will check again tho. Thanks.
  11. Elroythekid
    2,605
    5,657
    Sep 9, 2010
    Halifax Nova Scotia
    Thank you!
