60 series ecm swap from higher horse engine????
Discussion in 'Freightliner Forum' started by dustinbrock, Mar 14, 2013.
  1. dustinbrock
    dustinbrock Road Train Member
    1,308
    901
    Apr 19, 2012
    North Battleford, SK
    i have a 2003 columbia with a maxed out 430 horsepower 60 series. i want more juice but want to avoid a pdi tune. could i take a ecm from a wrecker yard thats rated at 500 horse and put it in mine? would it have to be out of a 2003? and more importantly can my engine handle it. shop forman at the local freightliner dealership said the injectors and turbos should all be the same between the different h.p. rated 60 series but i dont know if thats true.
    thanks for your input
  3. MNdriver
    MNdriver Road Train Member
    7,985
    4,371
    Feb 24, 2012
    I would suggest you contact Rebel127 here and he will hook you up the RIGHT way to get this done.
    Likely he can just tweak the computer you have and make it run right.
    Yes, he did my engine as well so I am a VERY satisfied costumer of his too.
  4. JohnP3
    JohnP3 Road Train Member
    1,594
    683
    Feb 21, 2010
    Rock Creek B.C. Canada
    Many things need to be looked at, the hard parts of the engine are one of them, the clutch, transmission, drive lines, the rear gears, axles, radiator, all are things that will need to be looked at.
    A Detroit dealer can give you the print out of hard part needed to change in the motor from the model and serial number of both units.
    Just a thought!
  5. dustinbrock
    1,308
    901
    Apr 19, 2012
    the truck is a heavy spec truck. clutch,tranny,driveline and rears will not be my issue...... ill check the rad.
  6. j-dawg
    j-dawg Light Load Member
    164
    47
    Dec 21, 2011
    Oil town, Ab
    Detroit's can be made to pull or outpull cats in about 25mins with the right hardware and knowhow
  7. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    what year are engines? do not mix up 12.7 and 14L ECMs
  8. dustinbrock
    1,308
    901
    Apr 19, 2012
    mines a 2003. i dont have another yet. but it would be from a 12.7 and to be safe i would try and find one from the same year.... try. just need to know if any of the hard parts differ between power classes.
  9. MNdriver
    7,985
    4,371
    Feb 24, 2012
    You are better off having someone tune your current ecm.
    Unless you can get an ecm with all the same exact components for injectors etc.
  10. dustinbrock
    1,308
    901
    Apr 19, 2012
    well thats my question.... are injectors,turbo etc the same and just the ecm tuned different or are the hard parts different. i would prefer the detroit ecm, i dont want to have someone tune mine.
  11. AUSSIE DAVE
    AUSSIE DAVE Road Train Member
    1,032
    176
    Feb 21, 2010
    OZ - Brisbane
    Forget buying ECM , get the tune, rebel helped me out and I'm in Australia , u will be happy dealing with him and the results he can give.
