Hi I am new to fourm. I need help with a 05 freightliner 60 series detriot 14l egr motor. The truck starts runs great for about 5-15 miles then it losses power. Have changed all filters. New turbo new injectors new fuel pump. Had air to air checked for leaks didnt find any. The shop cant find any codes on there computer. Any help woukd be greatly appericated.
60 series detroit 14.0 l power loss
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Cody9099, Nov 14, 2021.
I would find another shop with competent techs that will diagnose the problem instead of throwing parts at it, and giving up when they cant find any codes. If it's a fleet shop, well, you're kind of stuck. If you're mechanically inclined, you can check the EGR delta P ports and tubes for plugging. That's a common issue that can cause odd performance problems without logging faults. The 5 to 15 miles sounds like the problem is happening once it gets up to temp? That might be a clue also. Those engines will derate without a CEL if the air/coolant/egr temps get too high, but they're supposed to log an informational fault in the ecm.
AModelCat and BoxCarKidd Thank this. -
More than likely a vpod air pressure my 14liter was a beast after it was deleted
I have the same exact issue right now
But mine gives a check engine light and it cuts turbo boost in half
Although I just put new turbo
I also smell something odd like hot fumes maby Egr fumes
I’m not losing any coolant
Problem seem to happen at high speeds /high temp !
I’m going to delete it will let you know if that
Helps ! -
Thanks I will check it out
