5th Wheel Keeps Locking When Pulling Out From Under Trailer
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Ipé, Mar 2, 2023.
  1. Ipé
    Ipé Bobtail Member
    Mar 2, 2023
    Hey everyone! I am having an issue I just can not figure out. I have a 2017 Freightliner Casscadia. Everytime I go to drop a trailer, I lower the landing gear, unhook the air and electrical lines, and pull the 5th wheel release handle into the unlock position just as I did with my 2014 Volvo. When I try to pull away from the trailer, the release arm goes back in and the locking jaw goes back around the kingpin. I have tried pulling the tractor forward a bit first and backing the tractor up a little. Tried it with the landing gear just above the ground, just touching the ground, a couple turns past touching the ground, and even so high that I can see daylight between the trailer and 5th wheel. The only way I can unhook is by flagging another driver in the yard down and having them hold the release arm open while I pull forward, clear of the locking pin. Does anyone know what is going on?
  3. Bean Jr.
    Bean Jr. Road Train Member
    5,537
    9,875
    Mar 30, 2014
    The brand of truck is irrelevant. There are several brands of fifth wheel, the most common being Fontaine, Jost, and Holland. Each is available on every brand of truck. Knowing the fifth wheel brand may be helpful, but my guess is your locking mechanism is worn and it will have to be rebuilt.
  4. SmallPackage
    5,643
    18,036
    Dec 20, 2019
    Marion Texas
    What said above. Plus Release spring may be broke.
    Or it could simply be over greased. could have so much sticky grease and grime built up in the jaws that it cannot open up all the way and get past the release point any longer so they just close back up.
    Pressure wash clean and inspect.
  5. Judge
    89,658
    ViseGrips on handle against said fifth wheel works.
  6. Cattleman84
    Cattleman84 Road Train Member
    9,984
    71,268
    Nov 1, 2017
    The Sticks, Idaho
    Beat me to it... I guess not everyone was raised on a farm where such things were common practice.
  7. The Railsplitter
    The Railsplitter Medium Load Member
    321
    917
    Jan 23, 2023
    "BFE... and lovin' it!"
    If the handle is one of those that has a "catch" in the form of a piece of metal welded to the rod itself, that metal can be worn down in time... factor in ice buildup in winter and the "catch" no longer grabs the edge like it should. The handle rod may also be bent, you might wanna check it. Just my $.02 on the subject, I remember dealing with a release handle that wouldn't stay out like it should, and it was a PITA. The suggestion to use Vise-Grips is a good one, that'll keep the handle in place while you unhook... in essence, you're creating a new "catch" using the tool. If anything, it'll work until you figure out what needs to be done. Don't get me started on sticky slider pins, lol... :rolleyes:
    blairandgretchen Thanks this.
  8. Star Rider
    Star Rider Road Train Member
    1,623
    14,092
    Sep 23, 2019
    Bungee cord from handle to the side of the trailer works too.
    The Railsplitter Thanks this.
  9. dngrous_dime
    dngrous_dime Road Train Member
    3,150
    5,765
    Jan 28, 2014
    Lansing area, MI
    I occasionally have that issue, what I ended up doing is letting off the clutch in low gear, before releasing tractor brakes. That pull me forward an inch or two before I dump my bags to set the landing gear down gently. If I dump bags while brakes are set, it will sometimes allow the jaws to lock again.
  10. The Railsplitter
    321
    917
    Jan 23, 2023
    Or tarp strap... o_O
    Star Rider Thanks this.
  11. Lyle H
    Lyle H Road Train Member
    1,291
    2,938
    Apr 16, 2014
    Until you forget to unhook it and it goes flying into an innocent bystander with Dewey,Cheatem and How on speed dial.
