5th wheel issues. Didnt know where else to put this.
Discussion in 'Experienced Truckers' Advice' started by TexaSean, Jul 6, 2009.
  1. TexaSean
    TexaSean Bobtail Member
    43
    17
    May 12, 2009
    Austin, TeXas
    Ok, so I hook my truck up to a trailer. did the bump and pull to make #### sure it was latched. Raised the landing gear, hooked up lines etc, visualy looked to see that the little spring thing had poped in. WAS ALL GOOD.
    Pulled the trailer like 10 miles down around and through San Antonio, backed up to a dock, got loaded, pulled away from the dock, and SWOOSH my trailer falls on my last set of tandems. Had I ben going any faster than a snail crawl it woulda droped to the ground.
    Now looking at the 5th wheel, the hook thing is stuck in the CLOSED position and the handle you pull is all bent outa whack.
    NOW HOW, did I pull that trailer without droping it on the road, if it wasnt hooked up in the first place, and HOW did the trailer end up jumping out of the latch?!?!??!
    I dunno, but its a thousand bucks for a new 5th wheel, but im getting a rebuild kiit that cost 400 and some change, wich I hope works.
    Its a Holland 5th wheel, if that helps anyone.
    Any ideas as to how this happend would be great.:biggrin_25511:
  3. steelerfan67
    steelerfan67 Light Load Member
    135
    66
    Dec 5, 2007
    Lebanon, pa
    I can not say this is what happened in your situation, but years ago my husband and I had a truck that had an automatic fifth wheel release, we had hooked up to a trailer and pulled it over a 1000 miles, pulled into a truck stop hit a bump and the trailer fell off. We were lucky it was a light load and landed on the landing gear, some drivers helped dolly it and a driver used his truck to move the trailer, we went to a Volvo dealer, they had to disconnect the auto fifth wheel release, it was stuck half open and half closed. They said more then likely what happen was it closed when we hooked up, but it was not working correctly and the air was pushing the jaws open and when we hit the bump it was enough for the trailer to pop off. I thank god it happened in the truck stop and not out on the highway.
    If you have one of those maybe something similar to that might have happened, very scary!!!
  4. Allow Me.
    10,642
    12,099
    May 28, 2009
    Rancho Mirage, Ca.
    :biggrin_25512:This may be an un-solved mystery, but, sometimes, a driver thinks he's hooked up, but only partially. If the trailer's too high when he backs under, the kingpin is only halfway into the hole, and therefor, not fully locked in. Make #### sure the plate is flush to the floor of the trailer. Have you ever seen the kingpin override the plate and the driver keeps on going and, bammo, the nose of the trailer is flush against the rear of the sleeper?:biggrin_25518:
  5. IH Truck Guy
    4,118
    46,687
    Mar 2, 2008
    Purgatory
    This is why the "tug test" is not always accurate...
    You should always crawl under the trailer and make sure that it's secure..
    Is it a pain in the arse to do it.? Somedays it is..
    Thankfully your mishap happened at low speed and nobody was hurt.
  6. Working Class Patriot
    Working Class Patriot Road Train Member
    12,683
    23,164
    Jan 17, 2008
    Wherever and Whenever...
    Also check before you leave after a night at rest stops or truck stops.....
  7. Frenzy
    Frenzy Medium Load Member
    331
    186
    Mar 24, 2008
    Seattle, WA
    Your tires caught some road debris, which mangled the puller and opened the jaws. The trailer slid back and/or popped up causing the king pin to end up on top of the jaws (and reclosing them). The pin rested on top and you were darn lucky to have gotten it into the dock with out dropping the load. The trl slid out when you pulled away from the dock because the drag from the load was heavier than when the trl was empty.
    My best guess.
    Ken
  8. rockee
    rockee Road Train Member
    1,393
    673
    Apr 17, 2007
    Pacific Northwest
    My guess, which is only that, is that you hooked up but the jaws did not lock around the kingpin, like someone else said you had enough weight on there loaded to keep the trailer on, which Ive seen happen. On the bent handle, was it bent forward towards the truck:biggrin_2552:
  9. ziggystyles
    ziggystyles Road Train Member
    From what it sounds like, you checked the mushroom bolt and did a visual to make sure the locking bar was across, which it sounds like it was.
    However, you didn't mention a visual inspection of the king pin itself. Not only does it have to be seated in the crotch of the fifth wheel, it also has to be fully visable underneath the locking bar. If you look at the pin...its basically one solid cylindrical section of metal, with a narrow spot. That narrow spot is where the locking bar should slide across. You should be able to see the wider part of that pin underneath the locking bar.
    As far as the release arm...it might be damaged because the trailer wasn't properly connected. It sounds like the pin was on top of that locking bar, which I dont think is designed to take a vertical load ontop of it and as you were driving down the road...that pin kept bouncing down onto that bar.
