5700XE HVAC Question
Discussion in 'Western Star Forum' started by ShortCircuit, Dec 24, 2018.
  1. ShortCircuit
    ShortCircuit Bobtail Member
    26
    15
    May 7, 2017
    I have a suspicion my HVAC is stuck on recirculating air no matter what setting. It’s 15F outside and when I turn engine off and heater to minimum it keeps blowing air with ambient cabin temperature rather than pulling in cool outside air. How do I check the flapper/actuator? I took the glovebox and lower plastic cover and can see the blower motor and filters but are not sure where the outside air duct is?
  3. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    If it has the outside air cleaners, the intake for the cabin air is right tight against the cab on the near side of the right air cleaner. Right in front of the door, you will see the grill.
  4. ShortCircuit
    26
    15
    May 7, 2017
    I see the intake inside the cabin and can feel the air being pulled in, but where is the outside intake?
  5. ShortCircuit
    26
    15
    May 7, 2017
    Are you talking about inside the cabin near the passenger door? I’m trying to figure out how the outside air supposed to come in to blower box.
  6. uncleal13
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    Yup, it just comes in straight through the outer wall right there. If if has the air cleaners outside there.
    There is a flapper electrical actuator there. I wonder if it's bad.
