Location is Canada, Alberta
Looking at Triaxle 55ton rgn lowboy to move my machine around (42ton).
- Trailer tag plate says GVW 55ton
- Each axle rating is 10.5ton x 3=31.5 ton
Tractor is tridrive T800, isx15 600 with 18speed. 20k (9.5ton) front and 69 (31ton) rear.
Locally I am allowed 27ton in summer/winter on each tri group. I can plate to 63.5ton at the registry.
- 9.5t front + 27t rear drives + 27t trailer tri axle= 63.5ton GCWR
- Tractor is 10t + trailer 10t=20t tare, so payload 43.5t +/-
- Adding tandem jeep will add 21ton capacity same with tandem booster, so total 21t+21t=42ton (minus weights of jeep and booster) added capacity.
Question is, what's the heaviest I can haul when i add jeep and booster, but RGN is rated to 55ton.
My understanding is 55ton would be max i can load on the trailer, regardless of additional axles. However, I see guys move much heavier loads the more axles they add. At which point the trailer is too light for the load?
Thanks
55 ton RGN Lowboy Capacity
Discussion in 'Heavy Haul Trucking Forum' started by JohnIC, Dec 24, 2023.
Page 1 of 3
Good to know, I'll reach out to manufacturer for concentrated load per span specs. Trailer is 1993 Witzco RG-50 (55ton=120k lbs), which is equivalent to RG-60 model offered as of today on witzco website.
As for local laws, there is no questions. -
Looking at their website they rate all of the RG series trailers for the rated load in a 16' span. Considering they are a US based manufacturer and always have been they are not using metric tons for their ratings. Their 50 ton trailer is almost certainly going to be rated for 50T(100,000 lbs) in a 16' span.
You are mixing the US Short ton (1Ton = 2,000 lbs) with the Metric Long Ton (1Ton = 1,000KG = 2,200 lbs). 50 US Tons is about 43.3 Metric Tons. That's pretty much what you came up with for possible payload with your configuration.
All of the weights you provided are in metric tons but the trailer rating is marked in US tons. -
I must have missed this 16' span rating on their website, thanks for that.
The reason I used all metric calcs is because our systems and permits are in metric. The tag on my trailer is in kg (55,400), hence another reason for metric.
Whatever systems we use for figuring out the weight rating of cargo is ok and I wasn't aware of the difference between US ton and metric ton. Good to know
Now that we know the 120,000 lbs is per 16' span, do I extrapolate to come up with rating on 22' span (which is the well)?cke Thanks this. -
without seeing the trailer, you may not have a long enough neck to even load the steer axle on your tri-drive - If it is a 120” swing clearance you probably won’t get more then 15k up front.
on GVW it will be 55 ton including the empty weight of the trailer - so if the trailer weighs 22k - 98k would be max legal weight without
“overloading”.kylefitzy, beastr123, NightWind and 1 other person Thank this. -
So if the tag says 55400 kg gvw that is 122,136 lbs. so 122,136 - minus take weight trailer = net load capacity
This is why they are referring to in their nomenclature as a 50 ton.cke Thanks this. -
since you said you are in Alberta - take trip to Accusteel near Edmonton and have them take a look
so if you go 15k on steer plus max trident at 60.600(27500 kg) - that is 136200 lbs
tridrive maybe 25000 lbs plus 22000 lbs trailer = 47000 lbs tare weight
Net 89,200 lbs
machine 42 metric tons = 92,594 lbs
you may not be able to scale that machine unless you equipment is much lighter than that 47 000 I guessed.
hope this helps you in your actual calculations. -
Adding neck or boosters yah. Rating shrinks rapidly.
Page 1 of 3
