5 steps for parallel parking, is this accurate?
Discussion in 'Trucking Schools and CDL Training Forum' started by BigRigTex, Jun 8, 2014.
  1. BigRigTex
    BigRigTex Guest
    Step one: line up cone between trailer tandems
    Step two: turn wheel all the way to the left, and back up three to four seconds
    Step three: straighten up tractor, and back up two to three seconds, making sure not to hit the curb
    Step four: wheel all the way to the left, put entire vehicle in space
    Step five: straighten vehicle in space
    I take my test Friday hopefully
  3. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    step 4 should be right.....you need to get the rear of the tractor infront of the trailer. then step 5, turn hard left to straiten tractor in front of trailer.
    In step two, you turn hard left because you need the rear of the trailer to go right. Once you get the trailer at he right angle you turn right to get back in front of it. in step 4, you go hard right to get the rear of tractor in the space, In step 5 you go hard left untill tractor is in spot, pulling up as necessary. There is no exact science. Practice untill you have a feel for it.
  4. just_the
    just_the Light Load Member
    290
    167
    Mar 18, 2014
    Saltillo, MS
    This is a pretty good walk-through...
    http://www.youtube.com/watch?v=hM_pIOApuuE
  5. gpsman
    gpsman Road Train Member
    1,581
    1,211
    Dec 10, 2013
    45212/59759
    My students seemed to benefit a great deal from imagining they are seated in the rear (or front) of the trailer looking backward and steering from the tractor, but there is no substitute for "attentive" practice.
    Students tend to get justifiably frustrated, so taking a break and observing the success and failure of others can shorten the time to the light bulb going off and "getting it".
    That rig seems huge at first, but it will eventually shrink to a much more easily manageable size.
  6. ShopTalk
    ShopTalk Bobtail Member
    20
    Jan 1, 2012
    Orlando, FL
    Don't forget you never know which one your going to draw until the day of, Parallel Park (Conventional), Parallel Park (Sight Side).
  7. 12 ga
    12 ga THE VIEW FROM MY OFFICE
    1,568
    1,789
    Oct 21, 2013
    Central Michigan
    All states test programs are not the same. Michigan every body get the same exercises.
  8. BigRigTex
    BigRigTex Guest
    Texas only does a blind side parallel (or at least my city does, cause the parallel section at the dmv is on a one way street
  9. cabwrecker
    cabwrecker The clutch wrecker
    1,626
    1,423
    Mar 23, 2012
    Can confirm only blindside in Texas.
  10. NewNashGuy
    NewNashGuy Road Train Member
    1,616
    752
    Jul 27, 2011
    US and Canada
    Parallel parking is the easiest thing to do since a lot of places I go to park on the side of the street so I have gotten used to blindside parallel parking inbetween trucks (since another pulled off) in about 10 seconds one pullup. I just backup at an angle til my left side of trailer corner is in the hole, catch the truck up, and pull up to straighten truck and you are done. So if there is nothing but a truck behind me parked, I backup til the left corner of my trailer is lined up with the truck behind me, turn my truck into the space, and pull up a little it works every time. Blindsiding is a little different, I look at the front of my trailer to see when it is facing forward as much as possible to let me know that it is lined up.
  11. 12 ga
    1,568
    1,789
    Oct 21, 2013
    Central Michigan
    Been driving for 50 years and only did a paralell park once except in a range training situation with students in CDL school. It is a totally worthless maneuver dictated by desk jockeys in DC.
    Doc Daniels Thanks this.
