5.9L Cummins ISB - '07 Ram 2500
Discussion in 'Trucks [ Eighteen Wheelers ]' started by rollin coal, Nov 30, 2014.
  1. rollin coal
    rollin coal Road Train Member
    13,080
    25,855
    Mar 29, 2008
    TN
    A little off topic but thought I'd give it a shot. Today just driving down the highway heard a beep in the dash, check engine light came on, then immediately lost a lot of power. Truck feels very sluggish and runs rough. Doesn't smoke excessively. I was just put putting around when it happened I baby this truck. It only has a smarty jr on it since new. Now has 60,000 miles other than smarty jr pretty much stock. I turn the key off and on quick 3 times then wait and the check engine light blinks 10 times then once really quick. I don't really have time to deal with this today just wanted to post and see if anyone has any ideas. #### this sucks I always thought of my pickup as a sure thing.
  3. kvandenbos
    kvandenbos Bobtail Member
    8
    Dec 16, 2014
    MT
  4. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    hook up laptop with insite ore any obd-2 reader and U'll see codes
    rollin coal Thanks this.
  5. Terry270
    Terry270 Road Train Member
    1,455
    1,678
    Jan 21, 2014
    BG, KY
    Its most likely your lift pump. Need to check codes before anything else. You will most likely see a low fuel pressure supply code and/or low rail pressure code. Even if it has both codes it will usually be the lift pump
    Nothing to delete, its a 5.9 ;)
  6. rollin coal
    13,080
    25,855
    Mar 29, 2008
    TN
    It's been parked in my driveway since this happened I haven't started it up again. So I start it up to go to O'Reillys and have the code read. Darn things runs normal. No issues. But still has check light. Codes were P2146 and P0202 they gave me a printoff.
  7. Terry270
    1,455
    1,678
    Jan 21, 2014
    BG, KY
    P0202 Fuel Injector 2 Circuit
    P2146 Fuel Injector Group 1 Supply Voltage Circuit
    Sounds like a wiring issue to your #2 injector or the injector itself.
  8. rollin coal
    13,080
    25,855
    Mar 29, 2008
    TN
    I dropped it off at Dodge Thursday. They are going to pull the valve cover Monday and check for a short. I hope it's not the injector.....
  9. rollin coal
    13,080
    25,855
    Mar 29, 2008
    TN
    Bingo. Loose connection to the #2 injector. Breathing a sigh of relief at that one. Any idea what those injectors cost?
  10. Terry270
    1,455
    1,678
    Jan 21, 2014
    BG, KY
    Good deal. Injectors for your truck aren't that bad. Its not a powerstroke or dmax lol
  11. rollin coal
    13,080
    25,855
    Mar 29, 2008
    TN
