4x4 bulk head how to plz?
Discussion in 'Flatbed Trucking Forum' started by American-Trucker, Jan 9, 2012.
  1. American-Trucker
    American-Trucker Road Train Member
    10,371
    5,085
    Nov 8, 2009
    Charlotte, North Carolina
    K so while in training i asked how to make one of them nice little 4x4 bulk heads with a chain and got a 30 sec exsplanation.... can some one take some pics to show step by step how to do this?
    Thanks.
    American Trucker
  3. Shadowed
    Shadowed Light Load Member
    245
    92
    Jun 16, 2007
    Northern Wisconsin
    It is actually easier then you think and there was a video on youtube at one time. Might want to try doing a search. Other then that.. Stack your 4x4s so they line up with a stake pocket then drop one end of your chain down by the spool on one side of your pocket go under the pocket and back up the other side of the spool on the other side of the pocket and hook the chain up on top of the 4x4s about 16inches in. Kinda like making a big loop. Do the same on the other side of the trailer then put the binder in the middle on top of the 4x4s and tighten it up. Do it once and you will be like duh that was easy.. I would do the picture thing but my 4x4s are burried under my trailer. I will see if I can find the vid
  4. cruisecontrol
    cruisecontrol Medium Load Member
    340
    115
    Apr 13, 2010
    Rockingham, NC
    like he said....if you put the binder on top of your 4x4's and look at it..it would almost be self explanatory.."How am I going to hook chains to the binder to hold the lumber down?"
    1958Pete Thanks this.
  5. SHC
    SHC Spoiled Rotten Brat O/O
    8,484
    7,046
    Feb 26, 2011
    Westville, IN
    I put mine at the front of the lower deck and just use a 2" strap.....but that the luxury of pulling a step-deck :)
  6. 1958Pete
    1958Pete Light Load Member
    171
    64
    Sep 12, 2011
    Jonesville, Louisiana
    If someone gets a chance, could you post a picture of this or a drawing ?
    I'm kind of slow. Thanks !
    SHC Thanks this.
  7. SHC
    8,484
    7,046
    Feb 26, 2011
    Westville, IN
    He is just asking how to secure his 4x4 dunnage to the nose of his trailer (3+ pieces of lumber stacked on top of each other and held down with a chain)
  8. 1958Pete
    171
    64
    Sep 12, 2011
    Ok, thanks. I was trying to think how to properly make this work and this thread showed up. LOL And, I wasn't understanding the description above.
    So, I guess you just stack the 4x4s and lay a chauin across the top, secure both ends, and tighten the middle with a binder (?) .
    Thanks, again.
  9. Allow Me.
    10,642
    12,097
    May 28, 2009
    Rancho Mirage, Ca.
    Well, kinda....more like a hangmans noose, when securing to trailer. Just take notice when you see an empty FB with this set-up.
  10. THEPRIZEFIGHTER
    THEPRIZEFIGHTER Light Load Member
    109
    55
    Nov 4, 2010
    Dayton, OH
    It's pretty easy, all you do is stack your 4x4's in line with a chain spool. Then take a chain and loop each end over the chain spools on each end of the 4x4's. Hook the chain to itself. So you should have a loop of chain going around a chain spool and over your 4x4's hooked back to itself on top of the 4x4's about a foot to two feet in from the end of the end. Then take a bungee and hook it thru the chain to pull both loops toward the middle of the trailer. (That steps not necessary, but makes things a whole lot easier) Then just hook a binder up and pull the chain tight. I find it much easier to use a rachet binder rather than a snap binder.
  11. plentygood
    plentygood Road Train Member
    1,108
    729
    Apr 24, 2011
    USA / CANADA
    I like the snap binder for a bulk heads myself, when I hammer down on that wench bar I just feel it's more secure.
