40ft end dump trailer should i go tandem or spread axle ?
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by iamfargo, Apr 10, 2019.
  1. iamfargo
    iamfargo Light Load Member
    107
    22
    Feb 20, 2019
    What set up should I go with I’m hauling over the road I can only gross 80k ! So should I get a tandem axle or a spread and please list why! Thanks so much
  3. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    The ones that I see running between Phoenix and LA all the time are all aluminum and tandem axle
  4. wore out
    wore out Numbered Classic
    15,319
    184,946
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    I have a 39 ft spread. Hauling bulk is hard to keep the drives legal. With a spread you can load the tail and ride
    Oxbow, ChevyCam, spsauerland and 2 others Thank this.
  5. iamfargo
    107
    22
    Feb 20, 2019
    So how much does your trailer weight and how many tons can you haul I heard spreads weigh more
  6. wore out
    15,319
    184,946
    Jun 5, 2013
    379 pete 3406 275 wb. 39 ft Mate with 72 inch sides no liner. With 200 gallon of fuel I hit the scales at 33000. 23.5 is what I usually put on.
    With my 40ft x96 x78 Wilson hopper I hit em at 29200.
    Oxbow, spsauerland and iamfargo Thank this.
  7. iamfargo
    107
    22
    Feb 20, 2019
    My man I like hopper as well which one do you find more profitable ?
  8. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,129
    Mar 5, 2016
    White County, Arkansas
    I prefer a spread back there. 10 foot one inch gives you 40,000 and no more tandem cat scale games within reason. You are going to be heavy.
    You also will find that a airride spread when loaded gives you a very good ride. Better than most Cadillac's made.
    With a proper dump valve emptying your aft axle your trailer now thinks it's only 30 feet and becomes very easy to get into tight ready mix plants etc.
  9. iamfargo
    107
    22
    Feb 20, 2019
    Aft axle the rear axle ?? Or the front
  10. x1Heavy
    34,017
    42,129
    Mar 5, 2016
    My apology.
    The dump valve on the rear trailer axle, dumps the air suspension creating what is called a floater. Your front spread axle carries the entire trailer temporarily for making some extreme tight turning like for docking.
    I use terms aft because I was raised near the Atlantic Ocean and that kind of talk is pretty strong habit. Sorry for confusing. Aft means stern = Rear.
  11. iamfargo
    107
    22
    Feb 20, 2019
    Lol no problem they way you described it I knew you meant rear I just wanted to confirm that
    x1Heavy Thanks this.
