365 Cummins
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by mile marker 27, Mar 18, 2020.
  1. mile marker 27
    mile marker 27 Road Train Member
    1,229
    1,633
    Dec 4, 2019
    B8A8A88D-CF1C-4F63-A2C3-391D7CAB4725.jpeg 0BE7CD84-3BD9-489E-BFBB-A9F06047D84F.jpeg This engine is i a salvaged Pete, with a grain dump bed on it. What’s the ends and outs of the 365 Cummins. Is it a step time fuel system? Looks kinda like a derated 400, to me.
  3. spsauerland
    spsauerland Road Train Member
    4,296
    10,886
    May 31, 2010
    West Harrison, In
    Low flow cooling and STC injectors.
    Dino soar and mile marker 27 Thank this.
  4. mile marker 27
    1,229
    1,633
    Dec 4, 2019
    By the pics, do you think it’s still using the low flow system or been converted. Reason I ask that, is that I though low flows had only 2 small radiator hoses at the bottom of the radiator?
  5. MACK E-6
    48,113
    219,512
  6. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,431
    Aug 26, 2014
    It is low flow: 1 1/4 inch radiator hoses. It is still STC: Oil line running front to back under C brake connectors.
  7. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    What’s up with the AC pump . I bet it burns through belts fast or maybe it just the angle of your picture.
    spsauerland and StrokerTSi Thank this.
  8. spsauerland
    4,296
    10,886
    May 31, 2010
    West Harrison, In
    Looks like lower pivot bolt is broken.
    magoo68 Thanks this.
  9. SmallPackage
    5,273
    16,442
    Dec 20, 2019
    Marion Texas
    Its low flow that has the oil cooler without the spin on bypass filter next to the full flow. Most had 2 filters 1 fullflow and 1 bypass BC4’s were the first ones to do away with the need for the Luber-Finer 750.
  10. BoxCarKidd
    4,418
    6,431
    Aug 26, 2014
    You are mixing up low flow cooling with the number of oil filters.
    BCIII's had twin spin ons side by side. LF670 and a 777. They had high flow cooling.
    I thank the 88 BC4 was the first low flow cooling. Do not remember if they used twin spin ons or if that was when the single LF3000 came out.
    spsauerland Thanks this.
  11. 650cat425
    650cat425 Road Train Member
    1,548
    11,043
    Jan 26, 2020
    Pennsyltucky
    Not to change the topic, but I've always been a cat guy and I was wondering, what was the idea behind the low flow cooling?
