3406E vs C15
Discussion in 'Trucks [ Eighteen Wheelers ]' started by herbiemin, Dec 29, 2014.
  1. herbiemin
    herbiemin Light Load Member
    94
    50
    Dec 20, 2014
    Is there a fuel mileage difference between an E model and the C15? I've driven both but never had to worry about fuel, ran for a farmer. Liked the way the e model pulled better tho...
  3. little cat 500
    2,044
    1,090
    Jan 17, 2010
    Abbottstown PA
    pretty muchthe same thing exept the c15 has better gaskets an seals till you get into the accert thats a hole new piece of work
  4. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    I'd almost say a E-model with a 40 pin ECM with a early low nox file would edge out a 70 pin ECM C15
    So a 5ek,6ts,or 1lw all with a early low nox flash would be the best. The 70 pin ECM on 2ws or 6nz don't take that file, so probley not quite as good, but still not bad.
    Overall power would be better on the early Es better also.
  5. herbiemin
    94
    50
    Dec 20, 2014
    I wouldn't have an Acert from what I've seen and heard about them. Maybe I'm wrong tho
  6. russtrucker
    russtrucker Road Train Member
    1,767
    337
    Mar 27, 2012
    Central PA
    The later c15 like mbn and acert is pointless against 3406E. Best c15s are 6nz.
  7. SmokinCAT
    SmokinCAT Road Train Member
    1,773
    1,487
    Oct 20, 2010
    Hillsboro, OH./ Adrian, MI
    As far as reliability of hard parts the Acert will always have the upper hand, the bottom end is built much better than the older engines and the single piece steel pistons are much less likely to score than the two piece setup of the E model and earlier C15.
    Cetane+ Thanks this.
  8. russtrucker
    1,767
    337
    Mar 27, 2012
    Central PA
    But the turbo on acert sucks.
  9. Cetane+
    Cetane+ Road Train Member
    1,304
    882
    Sep 29, 2013
    Albany, NY
    NO, thats not the problem at all. Its ALL in the program that hurts acert owners.
    jtwhite and Dryver Thank this.
  10. russtrucker
    1,767
    337
    Mar 27, 2012
    Central PA
  11. SmokinCAT
    1,773
    1,487
    Oct 20, 2010
    Turbos are turbos and that is that, the manifold turbo is similar to what is used on the C12 and the big turbo is used with standard housings on many of cats industrial C15s and the euro C18 truck engine.
