3406E over fueling smoke out stacks
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Mad dog logistics llc, Jan 2, 2024.
  1. Mad dog logistics llc
    Mad dog logistics llc Light Load Member
    152
    37
    Jan 13, 2014
    Truck smokes when you start it up goes almost away when it gets hot but at idle you can see it. When driver pulls away and gets on it there isnt any smoke You can smell the diesel when by the truck
    Started about 1 year ago I knew Id over haul it so I let it be
    This truck had a diesel heater on the frame which I just bypassed (but never added water) it was shut off.
    Engine was over hauled problem still there
    Injectors just replaced, this did help some its not as bad.
    Burns no oil
    Drinks no water same as the day we rebuilt it.
    I removed the turbo exhaust side and you can see its diesel coating in the pipe.
    It has a new transfer pump new lines all but the line from the first filter on the frame to tank (replacing that this week)
    I use the same tool to adjust injectors as I do with another 3406E I have no problems there.
    My turbo spools up good the fins spin but not as easy as some of the others. (smokes at idle when turbo isnt working)
    New cam sensor
    No codes.
    Truck idles smooth!
    When you hit the pedel it hesitates (like mixture isnt correct) but when you idle at 1500 its smooth.
    ECM has not been looked at.
    Could the pump picking up air cause this? ECM gone out of whack? Could turbo cause over fueling
    I was going to hool up a clear hose this week to check the return for air.
    Truck is a 97 pete 379 turbo is a OR-7205
  3. Big Road Skateboard
    5,687
    29,604
    May 2, 2021
    Can you smell the fuel all the time? Somethin causing low compression? Overhead, jakes, etc
    @wore out
  4. Magoo1968
    Magoo1968 Road Train Member
    2,017
    5,395
    Mar 18, 2021
    St Malo mb
    I know guys who went through multiple injectors before they put together a good set. And also refuse to change them during a rebuild if they work good still..
    BoxCarKidd Thanks this.
  5. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,431
    Aug 26, 2014
    You can add me to that guys list.
    Magoo1968 Thanks this.
  6. little cat 500
    2,044
    1,090
    Jan 17, 2010
    Abbottstown PA
