3406e injector sizes
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 95kdub, Jan 10, 2012.
  1. 95kdub
    95kdub Bobtail Member
    16
    I would like to know what other 40 pin 3406e engines have the 57 injectors like the 5ek
  3. cowcatcher
    cowcatcher Light Load Member
    Almost all engines from a 5Ek up to a MBN use the 10R-8501. Some use a 10R-8502 but the 10R-8501 is the most common used.
  4. 95kdub
    16
    We are having some ECM problems with a 5ek and would like to find a good used one right now Cash is low. We would like to find a ECM that is 475hp and uses the 57 injectors. Only one that we have found is from a motor that had 58 injectors.
  5. 95kdub
    16
  6. underpsi
    underpsi Road Train Member
    1,266
    292
    Sep 18, 2008
    Toronto, Ont
    Easiest way is to get an ecm from a 1lw they all have 57's. Even easier get someone to flash your 5ek ecm
  7. 95kdub
    16
    The 5ek ecm the jake and cruise doesn't work and cat wants 1600 for a new one can't find a good used one so we were trying to find a good used ecm that uses the 57 injectors that's what in the engine. Thanks
  8. underpsi
    1,266
    292
    Sep 18, 2008
    Toronto, Ont
    Then find a 1LW ecm. All the higher horsepower 1LW's use the 57's
  9. 95kdub
    16
    I don't know where to find one I don't know anyone that has one of these engines. Do you know where I could find one?
  10. marmonman
    marmonman Road Train Member
    1,417
    2,842
    Dec 14, 2009
    central illinois
    Google it ! You can find anything on google!
    It's not rocket science just type 1lw ECM and start looking at all the hits it brings up
  11. Mr. Haney
    Mr. Haney Road Train Member
    2,693
    2,040
    Dec 17, 2008
    I have a used ECM for a 5EK I'll let go
    I'll send you a PM
