3406e inframe upgrades
Discussion in 'Trucks [ Eighteen Wheelers ]' started by tmeranto, Nov 22, 2016.
  1. tmeranto
    tmeranto Bobtail Member
    9
    Nov 22, 2016
    Doing a inframe on my 2ws 3406e are there any piston/liner pack upgrade like ceramic or teflon coated looking to put a reliable 750hp motor together thanks for the help! I seen running a 130-9710 cam with 58 injectors and a turbo but can I run the cam with my stock injectors?
  3. little cat 500
    2,044
    1,090
    Jan 17, 2010
    Abbottstown PA
    what injectors you have if there 57's it will run ok with the 9710 cam i had a 6nz that made way over 750 on 57's but it ran kinda rough at light throttle so i didnt like it
    tmeranto Thanks this.
  4. tmeranto
    9
    Nov 22, 2016
    Thanks not sure on this the injectors to be honest I'll do more reasearch. I just don't see a point in rebuilding it to stock
  5. tmeranto
    9
    Nov 22, 2016
    Yea they are 10r 8501 so 57s if I read it right would a fass fuel set up help with the rough low end?
  6. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,727
    Jan 30, 2010
    keep stroking.
    Ipd makes a one pc steel piston that I would recommend. Can take alot more heat and not swell up and score like the alum skirt ones will. Or get a Acert crank with the 16:1 piston packs for some extra bottom end grunt.
    Oxbow Thanks this.
  7. BigCam9670
    BigCam9670 Medium Load Member
    417
    4,585
    Jun 12, 2012
    Hudson, NY
    I have the exact same setup that you mentioned in my 1LW. I inframed it with an IPD kit and new cat head, I used new not reman 58's, and a new 130-9710 cam. I would do it all at once and be done with it. I sent Kurt (Mr. Haney) my ECM to flash while I was rebuilding the engine. Ive got 120k on it now and the truck works everyday, I think it is a perfect compromise between reliability, power and fuel mileage.
    SAR, bigguns and Oxbow Thank this.
  8. little cat 500
    2,044
    1,090
    Jan 17, 2010
    Abbottstown PA
    haney told me it was normal for it to run rough on light pedal i didnt like it so went back to stock cam
  9. T800H
    T800H Medium Load Member
    608
    295
    Apr 2, 2010
    The Keys
    another 1LW 1,000 plus hp marine cam 57 injectors 600 hp B/S program and damper by Mr Haney, idle as smooth as silk.
  10. lester
    2,914
    7,842
    Jan 2, 2012
    NW, Iowa
    You guys don't like a little lope in your idle? I've always like the sound of a gasser with a big cam and a rough idle. Not the same on a diesel?
  11. flatbeb mac
    flatbeb mac Medium Load Member
    508
    754
    Aug 16, 2015
    To me a lope in a diesel reminds me of a train.
