3406e fuel filter
Discussion in 'Trucks [ Eighteen Wheelers ]' started by gafred99, Oct 22, 2014.
  1. gafred99
    gafred99 Light Load Member
    155
    12
    May 28, 2009
    Tignall
    Hi,
    On my 97 3406e under the priming pump is a canister labled do not remove it is about 1.5" tall I have been told for years now replace it with an actual screw on filter.
    Anyone have a part number that fits there? Parts counter man not sure if it is same as ones that come with filter from factory. Any issue running it in series with the factory Davco 380?
    thanks,,,
  3. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    I should be the basic Cat secondaty filter, I don't know the Cat # off the top of my head, but all of ours use a Fleetguard FF5319, which they should be able to cross.
    Then look at your Davco. If all you run now is a Davco, you probably have 2 micron element in there, you want a higher micron filter in the Davco if you'll be using a secondary. We don't have Davco's, so I can't help you with part #s, but all of our Cats run a 10 micron primary with a 2 micron secondary.
  4. gafred99
    155
    12
    May 28, 2009
    Tignall
    The Davco filter has a detroit diesel 23521528, 16 micron ???
  5. GrapeApe
    2,215
    2,211
    Jan 7, 2013
    That is a 15 micron primary filter, you shouldn't run that as your only filter. That is a good filter to run once you get the secondary installed.
  6. rollin coal
    rollin coal Road Train Member
    13,087
    25,902
    Mar 29, 2008
    TN
    1R-0749 on that secondary filter if it is the same I use on a C15.
  7. gafred99
    155
    12
    May 28, 2009
    Tignall
    other than CAT filters , Baldwin, Fleetguard, WIX good for seconday?
  8. rollin coal
    13,087
    25,902
    Mar 29, 2008
    TN
    I use CAT or Donaldson. Whichever I can get the best price on by the case. I guess it doesn't matter but those are the only ones I use.
  9. JohnP3
    JohnP3 Road Train Member
    1,594
    683
    Feb 21, 2010
    Rock Creek B.C. Canada
    The Davco is the best system you can get buy the 2 micron filter, or even the 7.
  10. gafred99
    155
    12
    May 28, 2009
    Tignall
    Using 2 micron filter not to restrictive?
  11. QUALITYTRUCK
    1,801
    1,762
    Jun 14, 2009
    romulus,mi
    fleetguard ff5369w fuel/water seperator
