3406e (5ek) Replacing an oil Dipstick TUBE
Discussion in 'Trucks [ Eighteen Wheelers ]' started by skallagrime, Feb 15, 2015.
  1. skallagrime
    skallagrime Road Train Member
    3,836
    9,880
    Apr 10, 2012
    Indiana
    as the thread title might indicate, I am attempting to replace an oil Dipstick TUBE on my 3406e cat engine, beyond the obvious pain in discovering the tube snapped, (see picture, old broken bit next to shiney new one)
    beyond that (and price of course *grumble grumble 90 bucks, 1.87 extra for the $#%^ing rubber oring), I can install it quite easily (I think) PROVIDED that I can remove the old bit, I removed the bolt, and cant get the old tube to budge, put a bar on the bracket and hit it with a hammer, it didnt come even the slightest bit out of the socket
    do I need to remove the oil pan to get this thing out? the new tube (see picture, even put an arrow on it) has a hole in the part that sits in the pan, is that to hold some kind of retaining pin?
  3. wore out
    wore out Numbered Classic
    15,347
    185,314
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    The hole is so it can breath. Without it you won't get a proper reading. I usually pull the pan and knock it out from the bottom
    skallagrime Thanks this.
  4. skallagrime
    3,836
    9,880
    Apr 10, 2012
    Indiana
    i gathered it would be something stupidly easy to do that would require a way more laborious process (given the weather/not having a full size drain pan, im gonna be pretty chilly while i drain it 2 gallons at a go)
    BluePete05 Thanks this.
  5. wore out
    15,347
    185,314
    Jun 5, 2013
    You hit the nail on the head CAT famous for making things harder than they need to be
