3406E (5EK) high Fuel temperature Warning ( sensor location ?)
Discussion in 'Trucks [ Eighteen Wheelers ]' started by sunsation288, Oct 21, 2014.
  1. sunsation288
    sunsation288 Light Load Member
    55
    54
    Jan 12, 2014
    Hello all , i have one of my 3406E with a logged code
    174-0 High Fuel Temperature Warning
    174-3 Fuel Temperature voltage high
    and i don't know where is he ?
    can you help ?
    FAUTE FUEL TEMPERATURE HIGH.jpg IMG_1146.jpg IMG_1147.jpg IMG_1148.jpg IMG_1149.jpg IMG_1150.jpg IMG_1155.jpg IMG_1156.jpg IMG_1157.jpg
  3. Tmtbob
    Tmtbob Medium Load Member
    303
    186
    Mar 3, 2014
    Oklahoma
    Fuel temp sensor is the sender just to the left of the cat filter in the valve body. I don't see it in any of your pics but you can see the valve body I'm talking about in the 3rd pic
  4. sunsation288
    55
    54
    Jan 12, 2014
  5. Tmtbob
    303
    186
    Mar 3, 2014
    Oklahoma
    It's not showing up
  6. sunsation288
    55
    54
    Jan 12, 2014
  7. Tmtbob
    303
    186
    Mar 3, 2014
    Oklahoma
    It should be right behind your return line. In the far left of that pic is your return line with the silver 90 degree fitting. Maybe mine is different. I'll post a pic of where it is on mine. [​IMG]
  8. sunsation288
    55
    54
    Jan 12, 2014
    many thanks Tmtbob for you help , right now the truck have leave for the week , as soon he come back i will dig more
    many thanks again
  9. sunsation288
    55
    54
    Jan 12, 2014
    ****PROBLEM SOLVED**** , we have found the temperatur sendor was replaced by a potentiometer , and it was broken
