3406c cat motor running weird.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Wabbacha 409, Mar 18, 2018.
  1. Wabbacha 409
    Wabbacha 409 Bobtail Member
    17
    5
    Feb 12, 2018
    • My cat motor is blowing white smoke at start up, idles fine for awhile then starts loping, then idles fine, then more loping, some times it lopes and dies. Any ideas?
  3. Old Man
    Old Man Road Train Member
    4,597
    13,471
    Apr 3, 2009
    Oklahoma City, OK
  4. shogun
    shogun Road Train Member
    6,075
    72,159
    Jan 23, 2009
    Doing a regen
  5. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,732
    Jan 30, 2010
    keep stroking.
    Could be a few things. Have you drove it under load? Could be air in system ie- bad o-ring, cracked fuel lines from tank. Or weak check valve or transfer pump. Water or gelling if cold temps plugging up filter. Or a bad headgasket that isnt toltaly failed yet and your burning off coolant at startup. Last thing, bad o-ring on an injector or bad injector.
    SAR and Wabbacha 409 Thank this.
  6. SAR
    SAR Road Train Member
    2,756
    36,654
    Nov 26, 2011
    ND
    Is this a peec engine or mechanical?
    mtoo and Oxbow Thank this.
  7. Wabbacha 409
    17
    5
    Feb 12, 2018
    Not sure, it is. In a 1993 freightliner, don't know if it is the original motor. I don't know how to tell.
  8. SAR
    2,756
    36,654
    Nov 26, 2011
    ND
    On the left side of engine do you see a rod going from the pump to your foot pedal in cab?
    A peec engine will have a ecm on the left side with a bunch of wires.
    Can you give us the engine serial number? It will start with 3zj or 4 ck.
    Oxbow and spsauerland Thank this.
  9. mtoo
    mtoo Road Train Member
    1,935
    4,500
    Jan 15, 2011
    Retired on bended knee
    I would have thought any peec engines left would have been converted over to mechanical by now.
    peec was a pos in most peoples opinion. Converted it was a great running mechanical.
    If its cold outside, sounds like a normal start up for an old mechanical engine. Otherwise what @superhauler says
    Oxbow and SAR Thank this.
  10. Wabbacha 409
    17
    5
    Feb 12, 2018
    It is an ecm. I am 25 miles from the truck at this moment. Thanks for your help .
  11. Wabbacha 409
    17
    5
    Feb 12, 2018
    On the pump body there is 7e5888.
