3406B water pump
Discussion in 'Trucks [ Eighteen Wheelers ]' started by rank, Jul 14, 2014.
  1. rank
    rank Road Train Member
    9,916
    113,498
    Feb 11, 2010
    I used to have a small block chev that would leak coolant out of the "pee hole" to tell you when you needed a new water pump. Well, I am leaking some coolant out of a rather large 1" diameter hole on my 3406 and I am wondering if it's telling me I need a new water pump. I am pointing to the hole in the pic below.
  3. W900KW
    W900KW Light Load Member
    52
    14
    Jan 18, 2010
    south dakota
    yeah that is what it means
  4. BeenJammin
    BeenJammin Light Load Member
    256
    118
    Dec 17, 2013
    Cat will tell you that a slight amount of seepage is not an issue. They even used to make a standpipe kit for the weep hole to get away from excessive warranty swap outs. Here's the catch, if you're seeing coolant from weep hole, blowing back on oil filter, I'd be changing it. They can go from a "little Cat allowable seepage" to a full blown pour in a short time. Make sure you have correct radiator cap installed, so that you're not adding excessive pressure to system. Back in the days of your truck, it was probably a 7 psi cap and no more than 10.
    rank Thanks this.
  5. JohnP3
    JohnP3 Road Train Member
    1,594
    683
    Feb 21, 2010
    Rock Creek B.C. Canada
    Most trucks use at least a 10 lb cap and without preasure in the system the water pump can leak and also suck in air. Water pump failures are more prevalent in units without a water filter, and units that use DCA4.
    Just a thought!
    rank Thanks this.
  6. rank
    9,916
    113,498
    Feb 11, 2010
    Why is that?
    and why this?
  7. JohnP3
    1,594
    683
    Feb 21, 2010
    DCA4 is a coating not a protectant, it eats or does not stop the eating of aluminum, it does not work very well stopping corrosion on steel parts. when ever you change the WP on a Cat you want to really look at the cover for corrosion, the clearance between the cover and the impeller is very important for effective operation of the pump.
    Many units that use DCA4, especially the older Cummins, the steel pipes, for the cooling system corrode away form the inside out.
    A water filter gets rid of the sand and very fine particles of corrosion, out of the coolant, those fine particles are what wear out the WP seals, liner "O" rings, and the WP impeller.
    I used power cool or power cool plus coolant in every overhaul I did never had a coolant problem with any units after that unless some no mine put on a wrong filter, or added a in-compatable antifreeze.
    Just a thought!
    rank Thanks this.
