3406b Not making hardly any power
Discussion in 'Trucks [ Eighteen Wheelers ]' started by roberts11260, Jun 28, 2011.
  1. roberts11260
    roberts11260 Bobtail Member
    29
    Apr 21, 2011
    El Paso,TX
    When I first start the truck the motor will make a lot of power and pour black smoke but after about 15mins it falls off.
    Will only go about 55mph with a empty trailer.
    The previous owner said the injection pump was reset just 1000miles ago.
    Could I have a bad fuel filter or bad air filters?
    Strange how it has tons of power but after 15mins no longer has power.
    Any ideas
    1981/1988 359/378 Peterbilt.
    1981 frame and chassis with a 1988 378 cab and sleeper.
    Does anyone know what the part number is for a good CAT fuel filter?
  3. JohnP3
    JohnP3 Road Train Member
    1,594
    683
    Feb 21, 2010
    Rock Creek B.C. Canada
    Most every engine with a power complaint has the same routine, on a Cat you Change the fuel filters I like a FF211 Fleetguard and a 1212 primary Fleetguard. Check the fuel return line where it goes into the tank for flow.
    Check the CAC. starting from the turbo outlet pressurizing the engine intake checking for valve guide blow-by, the boost gauge, and anyother leaks. Check the AFC, for leakage. Do a valve set, check for full throttle travel, and check the turbo turbine for damage to the outer ends of the wheel. That will cover 95% of them.
    Black smoke is not power it is unburnt fuel.
    Tb0n3 and H2oburymatt Thank this.
  4. Diesel Dave
    9,214
    29,386
    Jan 20, 2010
    Hesperia, Ca.
    Check the fuel line's. They collapse inside and you won't be able to tell from the outside. They collapse under a load and it would restrict the flow.
  5. roberts11260
    29
    Apr 21, 2011
    El Paso,TX
    What is CAC? And what is AFC?
    How many filters are the there for the fuel?
    I just see a big BF614 filter on the motor.
  6. roberts11260
    29
    Apr 21, 2011
    El Paso,TX
    I found myself walking into the service bays of some big truck repair shops here in Dallas and just approaching people and talking to people. Got kicked out of a few shops, Finally pulled the same stunt at a Caterpillar shop here in Dallas.
    The guy I spoke with started saying the exact things I wanted to hear. Fuel system, Fuel system, fuel system.
    My rig is now at a Caterpillar repair facility here in Dallas. There are some guys that work there who may have as well written the book on Cat motors.
    I feel I am in good hands at this point.
    Shouldn't be long before I'm on the road and being stopped at every weigh station.
    I can't wait.
    As a new owner operator with the lower 48 Permits I am ready to start making some dough.
    :smt067
  7. kwforage
    kwforage Road Train Member
    1,047
    472
    Jun 3, 2007
    Wisconsin
    I use CAT 1R-0749 on my B model.
    H2oburymatt Thanks this.
  8. buttdiesel
    buttdiesel Bobtail Member
    Apr 27, 2009
    Victoria
    U will find the air fuel control valve is causeing the problem with the link in side the governor housing soon as it gets boost from the turbo it sets it self with the oil pressure from the engine then if u turn it off and start it agin it will be fine till it gets boost u have to dismantle the governor and check the link and the air fuel have had this problem before
  9. Shade Tree
    Shade Tree Light Load Member
    177
    44
    May 15, 2011
    Galloway Ohio
    That engine is notorious for three things. One being collapsed fuel lines as initially stated, second is two at once the air fuel ratio diaphragm rupturing and the AFR cover warping and leaking. You can check both by taking the cover bolts off and seeing if there is oil in the cover and you can also look at the cover gasket surface and see black soot where the boost gases have leaked. If there is oil in the cover the diaphragm inside needs replaced. Not a highl;y technical job but you must know what you arer doing when you re-install the AFR. Leave this function to a CAT person. The third is timing advance slipping or the carrier assembly coming apart. All have to be verified by taking timing cover off. If you taske the timing cover off and the weight carrier cover bolts off you can grasp the weight carrier and see if it slips if it does the assembly needs replaced. Leave this function to a CAT person because the weight assembly if not installed correctly can cause problems. The other rarity is if the Air tio Air Cooler ATAAC is leaking boost. The ATAAC needs pressure checked and you can visually look at clamping areas and look for black soot streaks. The clamps may be loose. They torque to a minimum of 90 in/lbs to 110 in/lbs. otherwise they leak or break.
    H2oburymatt and Ezrider_48501 Thank this.
  10. H2oburymatt
    H2oburymatt Light Load Member
    154
    52
    Dec 11, 2015
    I have 2 b models and run same for my primary.
  11. Largecar359
    Largecar359 Road Train Member
    1,075
    1,324
    Aug 13, 2011
    New Jersey
    Seems that all the most common things have been covered already. Sounds like afrc to me, diaphragm.
    noluck and H2oburymatt Thank this.
