What are the differences between theses B models? I’ve seen some 7FB’s that look to have a larger oil pan than my 4MG. Different turbo’s, pump, nozzles, aftercooler..........?
3406B, 4MG vs. 7FB
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by mile marker 27, Apr 29, 2022.
7FB could be JWAC or ATAAC. The JWAC were 24 degree timing with 14.5 to 1. The ATAAC were 21 degree. The 7FB has a sharp steep cam lobe that was hard on lifters. The timing advance is also hydraulic advance spring return. Uses 3421 nozzles
The 4MG is ATAAC (@425hp) has an 18 degree pump cam with a full hydraulic advance. (Both advance and return) the timing on a 4MG will respond a little faster, that and 15.2:1 compression will make it seem to be a little quicker or pull harder down low. They use 3423 nozzles.
Both use the narrow rod crank which is nothing to be concerned about just keep up on bearing rolls at 250k. I think the 4MG is the best of them personally.
The thing to remember is the nozzles have to match the pistons and the pump needs to match the nozzles for them to run like a few have the reputation of havingDale thompson, Oxbow, little cat 500 and 7 others Thank this. -
Is there a difference in oil capacity? The truck I bought recently has a 4MG and it originally had a 7FB. When I bought it, the oil was about an inch above “full” on the stick. I’ve ran it some and it does have blow by but the oil level never seems to drop. It also has a slight rear main leak. I was told that the 7FB can have a larger oil pan than the 4MG and was wondering if the previous owners had been over filling this engine? Maybe getting fuel in the oil?
AModelCat, mile marker 27, wore out and 1 other person Thank this.
I am not sure if oil capacity is a serial number break or not. I think it’s more of an arrangement number deal. That’s the number that gets you the internals of different hp, front or rear sump, oil fil location etc. another words how the naked block is assembled so to speak. The OT-spec will get you timing and fuel settings etc.
AModelCat, mile marker 27 and Oxbow Thank this. -
Oxbow Thanks this.
wore out, mile marker 27, spsauerland and 1 other person Thank this.
