3406a to 3406b
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Onewolf81, Jul 13, 2021.
  1. Onewolf81
    Onewolf81 Bobtail Member
    40
    33
    Jan 4, 2020
    I am restoring a 1973 Pete 359. It has a 3406a under the hood. I was wondering can I convert it to a 3406b? If so what do I need to change?
  3. Onewolf81
    40
    33
    Jan 4, 2020
    Let me also add that it’s a pc engine with glow plugs and not DI. By swapping cylinder heads can I convert it to DI and get rid of the glow plugs?
  4. SmokinCAT
    SmokinCAT Road Train Member
    1,773
    1,487
    Oct 20, 2010
    Hillsboro, OH./ Adrian, MI
    The pump will not bolt to an early A block, you will need to swap complete engines.
    Bean Jr. and spsauerland Thank this.
  5. Onewolf81
    40
    33
    Jan 4, 2020
    I was afraid of that. Can I replace the cylinder head and get away from the glow plugs and go to direct injection?
  6. Last Call
    Last Call Road Train Member
    7,568
    45,898
    Mar 15, 2021
    This statement is coming from a purest that likes things to be Original... and your post said ..Restoring so JMO but trying to convert a A model to a B model is not a restoration that being said ..
    Then why not save yourself time & grief.. just swap it out for a B model in fact if I did it I would go the extra step and get a ATA B model.. but I would also make sure that my air charge rad. had room to fit in there and not look like some abortion that was done under a shade tree in the Sunny valley trailer park by Billy Bob with a torch and 30 pack of Natty light.. again this is JMO.. Its your truck
    p608 and Stray_Dog Thank this.
  7. SmokinCAT
    1,773
    1,487
    Oct 20, 2010
    Yes, you would need to find a later DI head from an A model, they are not the same as the B.
    Oxbow, spsauerland and Roger McG Thank this.
  8. Onewolf81
    40
    33
    Jan 4, 2020
    Thanks everyone for all the input. The motor still runs strong so I’ll probably hold on on an engine swap. I will start looking for a later DI head for th a model
    Stray_Dog and baha Thank this.
  9. spsauerland
    spsauerland Road Train Member
    4,296
    10,886
    May 31, 2010
    West Harrison, In
    A JWAC B would be the best swap. I have a transplanted 400HP jwac B in my 82 W900.
  10. AModelCat
    154,235
    I looked into converting my PCTA to DITA. Spent a bit of time browsing SIS and picking other member's brains. For the trouble it'd be I just dropped 6 new PC cylinder kits in it and left it alone.
    Isafarmboy and spsauerland Thank this.
  11. Onewolf81
    40
    33
    Jan 4, 2020
    I’ve seen several people mention SIS. What is it?
