3000 watt inverter
Discussion in 'Ask An Owner Operator' started by Barbeque, Sep 19, 2016.
  1. Barbeque
    Barbeque Light Load Member
    199
    309
    Aug 25, 2015
    Everywhere USA
    I'm asking this here because I know company driversnormally don't have over 1500 watts aloud in the truck. But I have my own and put in a Power drive 3000 watt. It was doing pretty good at first. But now blows the 60 watt in line fuse while pulling hardly any power. REALLY getting tired of changing those $5 fuses.
    Has anyone else had this problem with these? And how did you fix it? Not sure if or how it could have gotten out of adjustment other than road vibration.
  3. ExOTR
    ExOTR Windshield Chipper Extraordinaire
    1,706
    1,893
    Jan 23, 2013
    Fort Worth, Tx
    If you're blowing 60amp fuses either you inverter is toast or you are running too thin of a gauge and overheating the entire wiring setup...
    tscottme Thanks this.
  4. tscottme
    tscottme Road Train Member
    How many watts are you pulling when these fuses blow. How many and what devices are causing the fuse to blow? What gauge wires and how long are the wires? The shorter and larger, the better.
  5. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    I use a 200 amp fuse for my 2,000 watt inverter.
    A typical 700 watt microwave would be enough to blow your fuse.
    I use at least 2 gauge wire, I have used welding cable in the past.
  6. Hurst
    Hurst Registered Member
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    This,..
    I have a 3500 watt pure synwave in mine and had a problem with the cables getting really hot when using my 1000 watt microwave. Also have a dorm style fridge powered during the day when the truck is running. Talked with a couple people. I ended up having to rewire it from my batteries with actual battery wires. Almost twice the size I was using,.. but no more problems. My inverter has been in the truck for just over 3 yrs now.
    Truck stop Power Drive/Road Pro inveters are cheap chinese junk in my opinion.
    Hurst
  7. CoyoteExpress
    CoyoteExpress Medium Load Member
    367
    173
    Oct 29, 2014
    Carlingford NB Canada
    Ifbmy 30year old stuff is still rightm
    3000W by 110v is 27.3amp
    So inverter to 12v
    12 to 110 is ~ factor 10
    27.3 amp by 10 is 273 amp ...
    So you need a min a 280 amp fuse
  8. Skate-Board
    Skate-Board Road Train Member
    3,801
    3,995
    Aug 9, 2014
    Merrimack, NH
    I have a 3,000 watt inverter. It takes 2 sets of wires each with it's own 250amp fuse.
  9. CoyoteExpress
    367
    173
    Oct 29, 2014
    The cobra inverter in this truck is now over 4 years
    At home i got a 1500 cobra and a 2000 ci
    Hina one both over 5 years .. no prob with them
  10. Hurst
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    Not sure I understand your reason to quote my post with your response?
    Hurst
  11. CoyoteExpress
    367
    173
    Oct 29, 2014
    Yours over 3 years
    My over 4 ...
    You got it
    Lol
