30,000 hours- curious how many others?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 04 LowMax, Nov 4, 2015.
  1. 04 LowMax
    04 LowMax Medium Load Member
    440
    250
    Feb 3, 2013
    Alberta
    Just went out and started the truck, noticed hour meter hit 30K. Got me curious as to how many others might be at or above that level with theirs? (And yes, it's been rebuilt).
    SAR and Ozdriver Thank this.
  3. mountaingote
    mountaingote Road Train Member
    2,026
    7,916
    Sep 22, 2012
    That, sir, is a lot of hours. How many miles?
    04 LowMax Thanks this.
  4. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    Our 2007 C15 Acerts range from 27-32K hours. We get a lot of PTO time, so hours are more than most and many of our maintenance items are based on hours rather than miles. For us, around 30k hours is pretty much time for an in-frame. We have one at 726,000 miles and 32,000 hours that has not been in-framed yet.
    SAR, 04 LowMax and mountaingote Thank this.
  5. cnsper
    cnsper Road Train Member
    5,869
    27,421
    Feb 28, 2014
    My 07 is at 855k and around 22k hours. Never been touched other than an actuator or two.
  6. T800H
    T800H Medium Load Member
    608
    295
    Apr 2, 2010
    The Keys
    mine has 27k but was in framed at 525k miles, has a total of 1,082,000 miles.
    had a Pete with a 12.7 that's still running around with about 1.5 mil miles never been touch, used to get 8 mpg and never smoked through the breather, which is rare for a Detroit at any amount of miles.
  7. rollin coal
    rollin coal Road Train Member
    13,087
    25,900
    Mar 29, 2008
    TN
    Does CAT ID have engine hours info somewhere in it? I would have to look you have me curious. It has a lot of info I just scroll thru and never really use. I keep it on water temp whenever the truck is running and go by it to turn the fan on/off. I also use the maintenance feature - reset it when I do a pm and it reminds me before I hit 12,500 miles that it's time. CAT recommends, I believe, OCI's of 300 hours for normal highway operation and I don't think I ever go that high. Really have no reason to keep up with hours so I don't.
  8. 04 LowMax
    440
    250
    Feb 3, 2013
    Alberta
    Not sure what Cat ID is? My hours are available on my "Data Star" unit. You must be over the million mile marker too now?
  9. Ozdriver
    Ozdriver Heavy Load Member
    767
    1,390
    Oct 16, 2015
    Australia
    I reckon I would easily have the record here as my 1980 KW has done over 5,000,000 kms with over 80,000 hrs on the CAT 3408 engine. Had 3 in frames with new liner kits/heads, bearing rolls approx every 700,000 kms, original crank with no wear patterns on journals, no electrolysis in block.
    Had the truck 20 years with two previous fastidious owners. I change oil at 9,500 liters (5,900 gal?) fuel burn, and CAT SOS sample oil every oil change and change and test coolant regularly. Also carefully warming up and shutting down engine helps a lot imo.
    KB3MMX and 04 LowMax Thank this.
  10. AModelCat
    154,533
    Back at the last fleet shop I worked for we had a pair of Western Star steam trucks ('03 w/ C12 I think). Both around 24,000 hours and about 40k-60k kilometers. They spent much of their lives on a handfull of locations running about 22 hours a day for months on end.
  11. Pool6710
    Pool6710 Medium Load Member
    662
    258
    Aug 10, 2014
    Minnesnowta
    I'm at 38000 and 748k
