I have observed that with both my power divider locked in and the rear diff locked , that the wheels on the rear axle (the one with the locker) turn at half the speed
of the wheel on the front axle. From time to time I encounter a situation where I have to chain up all axles to make a hill (grossing 140,000lbs). I usually lock it all up when I do this, but it occurs to me that might be pretty hard on something if they are trying to turn at different speeds? Maybe I should only be using the power divider in these situations? I tried to search for the answer to this but couldn't find this specific situation described.
3 Way Locker Question
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 04 LowMax, Dec 26, 2013.
Page 1 of 3
That doesn't seem possible to me, but go ahead and teach me something new.
Inland-Pilot Thanks this. -
With your combination you can still have one forward drive wheel slip while the other front drive wheel is locked the rear drive axle while the rear axle wheels are locked together. You do not have full locking diff on the front drive, just a locking interaxle diff. You would need full locking front and rear locking diffs with the power divider lock to lock both axles together.
beltrans Thanks this. -
Does your front axle lock too?
What you are describing is possible. The front wheels on one side spin at twice the speed because they are getting the full amount of power that the back two sets are sharing. That's how a diff works so when you go around a corner you don't ruin your tires.
I don't know if what you are doing is ok, not a good idea, or super bad. Just think about how the power gets to the ground though; if you have everything locked and only one set of tires is gripping, your whole 140k is being pulled by one half shaft. -
sounds like different ratio in front and back or different sizes tires. one of our trucks has full locker and they spin the same no matter what, or break. may be something out there I haven't seen, but that's how ours work. went back and read your post don't know about 3 way lockers could happen if one front wheel was not spinning.
Read post #3..........
I -
If you chain it up, all drive duals, it will probably quit spinning at double speed . I've never driven a Class 8 with differential locks, but when you chain up, and it works, wheel spin is reduced to little or negligible with only a power divider lock.
Your locked axle is not running half speed. If all wheels are getting equal traction they are turning the same speed. Your rear axle is going to run the same speed side to side no matter what as it's locked. There can be a difference in speed between your front axle side to side as it's not locked. That difference only comes into play when one side loses all traction it can spin faster but that speed difference is coming from the front differential.
An easy way to prove it is lock everything in on dry pavement and try to move. If what you say is true you will be gear bound and the truck would not move without breaking something.beltrans, tw1005tx, Cetane+ and 1 other person Thank this.
Page 1 of 3
