3/8" or 1/2" Chain
Discussion in 'Flatbed Trucking Forum' started by RoginVa, Aug 10, 2019.
  1. RoginVa
    RoginVa Bobtail Member
    14
    5
    Apr 14, 2015
    Been flatbedding for 4 years, just getting into hauling steel I-beam, 42K to 48K. 3/8 or 1/2" chains and is 8 plenty?
    D.Tibbitt Thanks this.
  3. Diesel Dave
    8,526
    23,505
    Jan 20, 2010
    Hesperia, Ca.
    I use 5/16’s. 3/8 and 1/2 is more for heavy haul equipment use.
    skellr and stayinback Thank this.
  4. stayinback
    stayinback Road Train Member
    3,911
    8,255
    Jan 24, 2014
    chicago,il
    Yeah 3/8 is plenty on beams....
    Older guys from the 60s and70s used to pull coils outta J&L steel (youngstown steel) throwing 1/2 chain in those days
    jamespmack and D.Tibbitt Thank this.
  5. beastr123
    beastr123 Road Train Member
    2,803
    22,847
    Jan 2, 2014
    Moose Jaw SK CAN
    1/2 inch on a flat is overkill because you do not have the anchor points rated anywhere near the WLL of 1/2 chain anywhere on a flat or step unless purpose built.
    3/8 chain is all you need and 8 gives you a total of 52K WLL if you have the rated anchor points.
    If the anchor points are rated at 5k then you need 10 to get over 48k WLL.
    Remember you are only required to anchor 50% of your load weight although most drivers add one or two "safety" chains to the minimum. Also remember the "1+1 for every 10 feet or portion thereof" rule.
    A 42ft load weighing 48K needs 5X3/8 gr70 for weight and 6 for length 1+5 (for over 40 ft) so 6 plus a "safety" not counting any tripping or stoppers you may want. This is if the trailer anchors are rated at 5K.
    1johnb, Winnyf1, SL3406 and 7 others Thank this.
  6. Zeviander
    Zeviander Road Train Member
    4,887
    36,995
    Jan 23, 2015
    Winnipeg, MB, CA
    Unless you are hauling a 45,000 lb piece of machinery, and only have 4 tiedown points, you really aren't going to get much benefit from 1/2" chain. Nor are there aren't many basic flats with tiedown points rated to 11,300 lbs to take advantage of that extra WLL.
    G70 5/16" is 4,700 lbs WLL and G70 3/8" is 6,600 lbs WLL. You only need 5x 5/16" chains to meet basic regs requirements for 45k, plus a couple for cross chaining at the front and an extra one along the length for "extra".
    3/8" is more common for equipment hauling, since they weigh a fair bit more and usually there are less tiedown points on the equipment (requiring higher WLL to cover the load weight). The only 1/2" chain I usually see in use by drivers are 2-3 foot sections on RGN setups with jeeps and boosters for those mega-heavy loads.
  7. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    When I puled a lowboy, I had 1/2 in chains, but I also kept 3/8 in chains to use on all the lighter equipment.
    Lepton1 and MartinFromBC Thank this.
  8. MartinFromBC
    2,769
    12,476
    Oct 19, 2018
    Yes, but heavy hauling equipment is so much different than the average flat or step deck hauling steel.
    I typically carry 16 1/2" chains, and 6 to 8 3/8" chains for low bedding... But again it is a different world.
    Lepton1, Cat sdp and Zeviander Thank this.
  9. starmac
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    When I started on my first lowboy job, all it had was 1/2 in chains, which I needed, but I also hauled some lighter, hoes, rollers dozers and such, where they were just overkill. It took me a while to convince them to let me pick up some 3/8 chains. lol
    MartinFromBC Thanks this.
  10. MartinFromBC
    2,769
    12,476
    Oct 19, 2018
    Unless it is a very small machine say under 40k lbs I usually use half inch on them...the smaller chain is nice for buckets and accessories or odd ball stuff we haul.
    I was honestly nervous about how to chain or strap down the armature i hauled this week. So i asked the guys who were helping me load it with the 2 cranes for advice because they move them. I was worried about damaging it, and it cost several million dollars so i was taking no chances. Rarely i use straps any more, but they were actually prepared to help me and wanted to help me.
    We chained the shafts at each end after they slipped on these special plastic collars to protect the shaft, and then they had special 9 inch wide straps they lent me that we threw over the middle, and didn't cinch them down ridiculously tight just nice and snug. Had 8 chains and 10 straps on it....didn't move at all, but I was leery about it at first...its not every day I haul a 118k lb armature. This week I take the housing for the generator up to Kitimat, then they can put it back together. While less lengthy, it is taller and wider, and heavier. Hoping that my permits are not too restrictive or make me run ridiculously slow speed.
    Lepton1, Cat sdp, Tug Toy and 2 others Thank this.
  11. MACK E-6
    48,130
    219,670
    Only I thing I ever used half inch chain was wheeled machinery since I was hauling it on mostly all spring ride equipment.
    Tb0n3 Thanks this.
