3.42
Discussion in 'Ask An Owner Operator' started by Abusumeyo, Jul 20, 2012.
  1. Abusumeyo
    Abusumeyo Bobtail Member
    Jul 20, 2012
    can anyone tell me what having a 3.42 Ratio truck means compared to a 3.5 ect?
    Road Killer Thanks this.
  3. WMGUY
    WMGUY Road Train Member
    1,684
    800
    Jan 1, 2011
    Nine Mile Falls, WA
    it is a little bit higher gear ratio which means higher speed and lower RPM's not much difference between the two
  4. 112racing
    112racing Road Train Member
    1,384
    20,548
    Nov 30, 2008
    pocono's, pa
    a 3.42 means the drive shaft will turn 3.42 turns to one full rotation of the wheel
    same applies to any ratio 3.55 means shaft turns 3.55 times to one full turn of the wheel.
    3.42 would have a higher top speed but less take off power than a 3.55 (not much difference between the two)
    3.55 would have more take off power but a lower top speed at the same rpm
    so when someone says a "higher gear" it means a lower number .......a "lower gear" would be a higher number
    magoo68, Dino soar and Road Killer Thank this.
  5. MNdriver
    MNdriver Road Train Member
    7,985
    4,371
    Feb 24, 2012
    3.42 has less leverage than a 3.55.
    depending on how the entire driveline is set-up with transmission gears and tire size, you can do a LOT of changing of final gear ratio at the ground.
    Dave_in_AZ, Road Killer and scottied67 Thank this.
  6. jbatmick
    jbatmick Road Train Member
    2,195
    2,458
    Dec 1, 2009
    hastings, Fl
    You would never notice the difference between a 3.42 and a 3.55 ratio.:dontknow:
  7. nutcase
    nutcase Light Load Member
    259
    100
    May 2, 2010
    Meridian, ID
    You can download the Cummins Powerspec program here: http://www.powerspec.cummins.com/site/home/index.html
    It will give you engine rpm at a given speed for every combination of components(transmission, tires, rear end ratio) you can imagine.
    They used to have a page where you could do it online but have changed their site, so I don't know if it is still available.
  8. Cowpie1
    Cowpie1 Road Train Member
    5,569
    4,651
    Nov 25, 2008
    Kellogg, IA
    Except a 3.42 would be about 50 less rpm on the engine at the same road speed compared to a 3.55.
  9. Starline
    Starline Medium Load Member
    357
    251
    Jun 1, 2011
    Middle Tn
    If you have tall rubber (11R 22.5), you can change to lo pro tires and change your final gear ratio by 50 rpm as well which will give you a little better pulling.
    BTW, 3.42 is a Rockwell... ratio 342 358 373 390 391 410 411 430 433 488 529
  10. MNdriver
    7,985
    4,371
    Feb 24, 2012
    Change tire size.....
    poor mans gear change.
  11. last 1
    last 1 Medium Load Member
    439
    184
    Nov 29, 2009
    Costs more to change 8 good quality drives than change gears so I don't think that qualifies as a poor mans gear change. :biggrin_25520: Sometimes a tire change is a better option also.
