3.42 gear ratio
Discussion in 'Flatbed Trucking Forum' started by Dadetrucking305, Aug 11, 2018.
  1. Dadetrucking305
    Dadetrucking305 Heavy Load Member
    980
    2,580
    Sep 15, 2011
    Cibolo,Texas
    Wondering If a 3.42 gear ratio is good enough for flatbed at 80k? Motor would be a DD15 505 hp and 13 speed.
  3. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    What year is the truck and what size tires?
    The thirteen speed gives you some flexibility.
  4. Dadetrucking305
    980
    2,580
    Sep 15, 2011
    Cibolo,Texas
    I’m looking at 2015 Cascadias.What size tires would they need to be? Having trouble finding one with 3.55 gear ratio.
  5. Dadetrucking305
    980
    2,580
    Sep 15, 2011
    Cibolo,Texas
    Most of the ones I’m seeing are 22.5
  6. Espressolane
    16,975
    102,306
    That is exactly what my last truck was. Had no problems with that set up. Pulled fine, reasonably good fuel economy.
    Dadetrucking305 Thanks this.
  7. Dave_in_AZ
    369,986
    Mines a 3.58.
    3.58 or 3.55 is just different manufacturers.
    Look for an old Gordon truck. The light blue ones.
    Rollr4872, cke and Dadetrucking305 Thank this.
  8. KB3MMX
    KB3MMX Road Train Member
    3,069
    2,588
    Dec 29, 2014
    Orrstown, PA
    RPM vs MPH.
    So many variables, the rear end is only part of the picture.
    FYI ... My current truck is 2.64 with overdrive and i run gross frequently... I'm sure you'll be fine.
    cke and Dave_in_AZ Thank this.
  9. Dave_in_AZ
    369,986
    Depends where you plan on running too.
    If you're gonna be in the Midwest and more on the flat, the 3.42 or 3.36 or 3.23 is a good choice.
    cke, Dadetrucking305 and brysol01 Thank this.
  10. TripleSix
    127,950
    The drivetrain should be good. A mid roof would be better. What wheelbase are you looking at? I wouldn’t go really short on the web. BTW, 244wb looks good on an aero hood.
  11. Dadetrucking305
    980
    2,580
    Sep 15, 2011
    Cibolo,Texas
