250 Cummins Jakes
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 64Peterbilt, Jun 4, 2018.
  1. 64Peterbilt
    64Peterbilt Bobtail Member
    18
    19
    Jun 3, 2018
    I recently bought a Peterbilt 351 as a project and it has an old NH 250 Cummins in it. I am debating wether to fix up and keep this motor in it or repower it with a newer NTC 350 or 400. One of the things i want is jakes and my truck does not currently have them. I know that the 250 is an 855 ci same as the NTC but i dont know about the heads and stuff if they are different. I know there are many benefits to upgrading to the NTC but i am not sure on all the technical pros and cons to that swap.
  3. Bean Jr.
    Bean Jr. Road Train Member
    5,468
    9,698
    Mar 30, 2014
    The 250 isn't the NH series, it's the NC series, which is the same as a 335, 350, etc. There are some difference in a 290 and big cams, but essential a 335 is a 250 with a turbo and a small cam is a 335 with an after cooler, hence NTA , turbo aftercooled.
  4. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,431
    Aug 26, 2014
    Jakes no problem but a standard 250 does not have piston cooling nozzles. Not advisable to but a hair dryer on one.
  5. slickWillie1980
    slickWillie1980 Medium Load Member
    420
    35,545
    Sep 2, 2015
    Mt Olive, NC
    Pics or it don't exist!!!!
    BoxCarKidd and Bean Jr. Thank this.
  6. kranky1
    kranky1 Road Train Member
    2,253
    8,850
    Sep 16, 2015
    Ontario, Canada
    If its an 855 it is an NT. NH were 743
  7. DougA
    DougA Road Train Member
    1,429
    8,892
    Dec 16, 2013
    Retired,In my shop in Md.
    NH-195,NH-220, 5 1/8 bore,743 cid.,no factory turbo charging. NHC-250 5 1/2 bore,855 cid.,N.A., was standard equipment in a lot of trucks,back in the day. Back then Cummins also made a Super 250,927 cid,never caught on,only ever saw a couple,crank issues.
    Also NTC-335 did not have an aftercooler.
    Bean Jr. Thanks this.
  8. SmokinCAT
    SmokinCAT Road Train Member
    1,773
    1,487
    Oct 20, 2010
    Hillsboro, OH./ Adrian, MI
    That botched attempt at the 927 scarred Cummins for life, not once after that would they ever try to go to a longer stroke in the 855.
  9. 64Peterbilt
    18
    19
    Jun 3, 2018
    slickWillie1980 Thanks this.
  10. 64Peterbilt
    18
    19
    Jun 3, 2018
    Well everything ive found researching it says its an 855. I found the manual online and it says 855 as well so im not sure.
  11. slickWillie1980
    420
    35,545
    Sep 2, 2015
    Mt Olive, NC
