24k vs 30k trailer
Discussion in 'Expediter and Hot Shot Trucking Forum' started by rccarlson22, Oct 17, 2019.
  1. rccarlson22
    rccarlson22 Medium Load Member
    431
    761
    Aug 27, 2019
    I’ve got a 2019 Ram 3500 Dually with the 4.10gears.
    Would it be overkill to get the 30k trailer or could that truck handle the tongue weight when it’s loaded?
    Is there anything I can ask a trailer manufacturer to do to reduce tongue weight?
    TIA
  3. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    go bigger or go home.
  4. rccarlson22
    431
    761
    Aug 27, 2019
    That’s what I want to do but I don’t want to overload the truck, particularly on the drive axle
  5. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    get a bigger truck
    rccarlson22 Thanks this.
  6. truckdriver31
    6,989
    8,352
    Sep 18, 2013
  7. rccarlson22
    431
    761
    Aug 27, 2019
    I already have the truck no going back on that anytime soon
    truckdriver31 Thanks this.
  8. Capacity
    Capacity Road Train Member
    1,499
    3,116
    Jul 28, 2019
    Neenah Wi
  9. rccarlson22
    431
    761
    Aug 27, 2019
    Has anyone with a 3500 ran a 30k flatbed gooseneck and loaded it up?
  10. 24kHotshot
    24kHotshot Heavy Load Member
    801
    874
    Feb 19, 2019
    New York
    I have a 3500 chassis cab and ran with a 27k 4 car hauler for a while and currently with a 26k. Also have a full steel upfit and 74g fuel tank that makes my truck weigh almost 9.5k with no trailer. I'm registered for 41k.
    Heaviest I've scaled so far at a weigh station was 36,600 gross. Full load nearly bottomed out my suspension but mostly because of the wheel well brackets. Getting airbags installed soon that would hopefully help eliviat the problem and also going to get a welder to reposition the wheel well bracket.
    A loaded 30k will put 6-7.5k lbs on the drive axle.
    Lite bug and rccarlson22 Thank this.
  11. rccarlson22
    431
    761
    Aug 27, 2019
    Do you know the payload on these? It’s the same truck you have but with a bed
