24' Two Axle Vehicle Weight Question
Discussion in 'Experienced Truckers' Advice' started by MercySakesAlive, Oct 4, 2014.
  1. MercySakesAlive
    MercySakesAlive Light Load Member
    104
    45
    Aug 8, 2008
    seattle ,wa
    This is what I know:
    1. I have a straight truck with two axles and a 24' box.
    2. My legal GVW is 26,000.
    3. This is a non-CDL truck with air brakes
    4. I am using it for commercial hauling sound gear
    5. I run out of Washington State and want to go to the lower 48 states.
    This is what I want to know:
    1. What gross weight can I legally load my drive axle to? 14,000 lbs .... 20,000 lbs? .... something else?
  3. kctrucking
    kctrucking Bobtail Member
    47
    4
    Jul 14, 2014
    Take the truck to scale with full fuel tanks get gross weight subtract that from 26000 . Door frame should have axle limits for front and rear
  4. snowwy
    snowwy Road Train Member
    20,524
    13,261
    Jul 6, 2009
    what's the distance from the center of the front steer to center of rear drive tire. then we can give you a bridge law weight. you may or may not be able to actually haul that weight, though.
    drive train limit. tire limit. probably a few others that can dictate what you can actually gross out at.
  5. Allow Me.
    10,642
    12,097
    May 28, 2009
    Rancho Mirage, Ca.
    Well, if your GVW is 26K, as mentioned above, get your empty weight, subtract that from 26K to get your net weight. Whatever that weight is, with the configuration of a 24' straight truck, (distance between steer axle and drive axle) Wherever you place the payload in the box, you shouldn't be overweight on any axle. (because they're close enough together)
  6. Pullin2
    Pullin2 Crusty Canuck
    1,991
    3,611
    Nov 5, 2011
    Whoville Pub, Long Island
    All good points ^^ ..... what type of tires are on there ? What are their specs ? Besides what the door decal says for the axels (with a particular type of tire .... ) what does the PERMIT and/or registration say ?
  7. street beater
    street beater Road Train Member
    4,578
    20,669
    Apr 18, 2014
    cold as hell, MN
    Not much, we got some 33600 26' single drive axel and they can only scale around 7 tons
  8. mugurpe
    mugurpe Medium Load Member
    395
    274
    May 5, 2013
    Arlington, MA
    As was previously noted, it's best to get it scaled so you have a sense of the tare weight on each axle. The plaque in the cab (drivers door) will probably tell the axle capacities. Then you'll have a sense of available weight and how it should be distributed. Some 26K gvw trucks have a 8K axle and an 18k axle (or different if it's a cabover) but that basically adds up to 26K and so you have to hypothetically balance the load perfectly to legally scale 26K. Some are built with heavier axles and are still rated for 26K so you might have a truck with a 10K front and a 18K rear which gives you a little wiggle room for how you load the truck if you're going to be at 26K. Most states also have a "grace period" kind of thing where if you're within 500lbs on an axle you're good.
    Some penske rentals tare at 17K so you have a 9K payload some at 19K so you have a 7K payload. It depends on the chassis, box construction and if it's got a lift gate. FRP boxes are heavier, aluminum sheet boxes with slats and rails are lighter. Liftgates are heavier than ramps, etc. Even engine weight can play in, an international with a vt365 will be a couple hundred lbs heavier than a dt466 but will pull like crap.
    It's best to get it weighed at a scale that gives axle weights. Scrap yards and dumps have scales but only give gross weights not axle weights but are usually easier to find locally.
    Also, cops are much less likely to mess with you if you're close if it's an under CDL truck. Also, I suspect sound equipment is not dense enough to overload a 24' 26K truck unless it's all crates of cables and bags of sand.
