235/80/22.5 tire
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Don2WS, Oct 25, 2011.
  1. Don2WS
    Don2WS Medium Load Member
    306
    26
    Feb 26, 2010
    Sturtevant WI
    i bought a set of of ten 235/80/22.5 michelin xrv tires brand new with stickers made in 2008. i paid $100 per tire they were bought from an rv dealer but the guy passed away and never got a change to use them. The wife told me to give her 1k and take the tires because she needed the house empty by today. So now im wondering would mounting these tires on one of the trailers be ok right now im moving trucks from sturtevant to davenport and back ? I still have to do the math and find out the max load per each tire and compare the height to one of the low pros i got on but whats you r opinion on these tires
  3. morninshow
    morninshow Bobtail Member
    7
    Feb 6, 2011
    mi
    235/80r22.5 outside dia 37.1" 4410 lbs per tire dual application @ 110psi
    this tire should be on a 7.5" wide wheel you may and probably have 8.25"
    255/70r22.5 outside dia 36.7" 5510 lbs @120 psi
    275/80r22.5 or 295/75r22.5 outside dia 40.1 5675 lbs @ 110 psi
  4. Flightline
    Flightline Road Train Member
    2,345
    1,165
    Oct 1, 2011
    Almost There
    Might keep in mind, tire life is not just the miles or wear but also it's age. The belts in most tires, start to break around 5-7 years old. I've seen this on tires with no wear but just age.
  5. blanco
    blanco Road Train Member
    1,221
    296
    Nov 20, 2009
    Gwinnett County, GA
    michelin xza3 have a 700,000 miles 3 recaps warranty.
    Don2WS Thanks this.
  6. Don2WS
    306
    26
    Feb 26, 2010
    Sturtevant WI
    thanks for the heads up
  7. wraythewanderer
    wraythewanderer Bobtail Member
    If they don't work for you-would be interested in four to six tires.
    wray
