22.5 tall vs 24.5 tall tires and 5th wheel height?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Onemanshow, Feb 1, 2019.
  1. Onemanshow
    Onemanshow Light Load Member
    101
    63
    Jan 29, 2016
    richmond hill on
    Hey everyone, would you know if pete's low air with 22.5 would be the same 5th wheel height as with low low air on 24,5?
  3. Rideandrepair
    17,209
    55,822
    Aug 8, 2015
    24.5 will be higher. 24.5 lo pro are same size as 22.5 tall. 5 th wheel Height would stay the same
    I glide 47 Thanks this.
  4. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,431
    Aug 26, 2014
    Many different 5th wheel options. I like to measure ground to plate.
  5. Onemanshow
    101
    63
    Jan 29, 2016
    richmond hill on
    But suspension is also lower in low low air
    KB3MMX Thanks this.
  6. Onemanshow
    101
    63
    Jan 29, 2016
    richmond hill on
    i know that you could get different base for the fifth wheel, i guess in combination with low low and low base fifth wheel it might be even lower .
    KB3MMX Thanks this.
  7. Rideandrepair
    17,209
    55,822
    Aug 8, 2015
    The short answer is height would increase 1 inch. Since tires are 2 inches taller
    KB3MMX and BoxCarKidd Thank this.
  8. Rideandrepair
    17,209
    55,822
    Aug 8, 2015
    No that’s wrong the tires are 3 inches taller, so fifth wheel height would be 1.5 inches higher, Sorry my bad
    KB3MMX Thanks this.
  9. Rideandrepair
    17,209
    55,822
    Aug 8, 2015
    Ok I’ve had my coffee,I’m sorry, I see you’re question is about air ride, not so much tires. Someone with knowledge of Lo and Lo Lo air ride hopefully can help. Good Luck
    KB3MMX Thanks this.
  10. pushbroom
    pushbroom Road Train Member
    1,777
    7,253
    Sep 1, 2012
    Low air leaf to low low air leaf is a 2 inch difference due to the mounting points being higher on the frame.
    KB3MMX, Oxbow, Rideandrepair and 3 others Thank this.
  11. KB3MMX
    KB3MMX Road Train Member
    3,069
    2,588
    Dec 29, 2014
    Orrstown, PA
    40" 22.5LP
    42" 11R 22.5
    42" 24.5LP
    44" 11R 24.5
    If LL suspension is 2" lower than regular low, the difference should actually be net 1" lower FW for the 11R 24.5 truck on LL suspension.
    The 2" tire difference only gives 1"+ ride height.
    You're taking away 2" by going to LL air.
    Now if it's 22.5LP tires on low air, they should be the exact same as 11R-24.5 on LL air
    Rideandrepair Thanks this.
