2010 T660
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by 5133, Oct 28, 2019.
  1. 5133
    5133 Bobtail Member
    4
    Oct 28, 2019
    2010 T660 Wipers flash not working nor any of the parking wipers... Only the high speed wipers working.
    I replaced 2 relays and 2 fuses for the wipers and wiper wash.
  3. stillwurkin
    stillwurkin Road Train Member
    1,756
    2,856
    Dec 2, 2017
    When mine did something like that on my 379 it was wires corroded off up, on firewall not far from the wiper motor. They wouldn't park properly, intermittent would stop halfway through cycle, and wipers would park at odd positions on windshield.
  4. Tx Countryboy
    Tx Countryboy Road Train Member
    1,968
    4,437
    Sep 18, 2019
    Kenworth had a recall on late 2010's-2015. for water leaking into windshield wiper motor.
  5. Tx Countryboy
    1,968
    4,437
    Sep 18, 2019
    Most would only work on high.
  6. 5133
    5133 Bobtail Member
    4
    Oct 28, 2019
    Is that gonna disable the windshield washers ?
  7. 5133
    5133 Bobtail Member
    4
    Oct 28, 2019
    Just checked for any wiring corrosion's or loose connections. haven't found nothing.
  8. spsauerland
    spsauerland Road Train Member
    4,296
    10,886
    May 31, 2010
    West Harrison, In
    There is a separate fuse for wiper park. The recall was quite impressive, they ziptie a piece of plastic over the wiper motor.
    pushbroom Thanks this.
  9. 5133
    5133 Bobtail Member
    4
    Oct 28, 2019
    After 3days of checking the wipers motor, washers motor, 2 relays 2 circuit breaker fuses, Stalk switch, CECU, CECU harness, it turned out to be 5V [relays] fuse in fuse box.
    Pacific Islander Thanks this.
