2001 International 9100i heater/ac problem.
Discussion in 'International Forum' started by truckinglongisland, Dec 15, 2012.
  1. Bill Grant
    Bill Grant Bobtail Member
    7
    Got power to everything in low to med speed solenoid on med and high on high but all power to resistor stops when I change speed from low
  3. Dsmth
    Dsmth Bobtail Member
    Ok I have two 9200's one the fan didn't work on high replaced resistor. Bingo works great. The other one only works on high replaced resistor that didn't help. Replaced a relay that didn't help either. Any suggestions?
  4. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    What year? Most of them, Low and Med go through the resister and back up to the high speed relay, but connect to the fan through the relay between 87A and 30. The wire between the resistor and 87A might be open. It's 75T if you have a late 90's model.
  5. Adamyoung03
    Adamyoung03 Bobtail Member
    Have 2005 9900i replaced compressor and drier filled with 3 1/2 lbs of Freon. Work for a day then back to only blowing hot air. mechanic said there was a clog in the system? Not sure if that's the real problems any suggestions.
  6. Heavyd
    7,749
    6,184
    Feb 4, 2009
    If you have an APADS, see if it is flashing a fault code.
    Check if your compressor is getting voltage with a test light when turned on.
    Recheck your a/c charge with gauges.
